2019-11-15 22:42:16.320 [ome.event.ItemCommandEvent] - Item 'sonoff4chR2L1_2mans' received command ON
2019-11-15 22:42:16.333 [nt.ItemStatePredictedEvent] - sonoff4chR2L1_2mans predicted to become ON
2019-11-15 22:42:16.357 [vent.ItemStateChangedEvent] - sonoff4chR2L1_2mans changed from OFF to ON
2019-11-15 22:42:16.364 [vent.ItemStateChangedEvent] - sonoff4chR2L1_2mans changed from ON to OFF
2019-11-15 22:42:16.489 [vent.ItemStateChangedEvent] - sonoff4chR2L1_2mans changed from OFF to ON
In your case, the two channels are probably fighting in addition to the usual autoupdate dithering.
expire="10m"
That is a valid configuration by the way, but probably doesnât do what you expect. 10 minutes after the last command or update, it will set your Itemâs state to UNDEF. The binding(s) wonât do anything about sending that to the device.
autoupdate=off is the right solution for my case, thank you!
the 2 channels do not fight over the status, as the tele channel only runs once in a while.
I do use expire=â10mâ exactly because I want the status to be UNDEF if tele stops working.
this way I know the thing has a problem and went offline. As tele runs every 5min, the 10min expire time never gets activated.
