HI again everyone, I just built a new system with an raspberry pi4 (booting from usb-ssd), Openhabian 1.6.5, Openhab 3.1.0
I have the older Insteon hub (2242-222) and a handful of different devices. Everything is working except my 8 button keypadlink-Dimmer (2334-232).
I can receive commands from all the buttons on the keypad into Openhab, but I can’t change the state of any of the buttons by sending a command from Openhab into the keypad, however I can Control the Dimmer from Openhab.
I’ve tried adding the device by textual definition via the things file, and I’ve also tried using the gui to add it, both have come to the same result as described above
here is my thing definition:
Thing device Foyer_Keypad [address="2b.98.42", productKey="F00.00.16"] {
Channels:
Type keypadButtonA : keypadButtonA [ group=1 ]
Type keypadButtonB : keypadButtonB [ group=2 ]
Type keypadButtonC : keypadButtonC [ group=3 ]
Type keypadButtonD : keypadButtonD [ group=4 ]
Type keypadButtonE : keypadButtonE [ group=5 ]
Type keypadButtonF : keypadButtonF [ group=6 ]
Type keypadButtonG : keypadButtonG [ group=7 ]
Type keypadButtonH : keypadButtonH [ group=8 ]
and here are the related Items:
Dimmer DrivewayLights "Driveway Lights [%.0f]" (ExteriorDimmers) { channel="insteon:device:home:Foyer_Keypad:loadDimmer" }
Switch keypadSwitchB "Foyer" { channel="insteon:device:home:Foyer_Keypad:keypadButtonB" }
Switch keypadSwitchC "All Outside" { channel="insteon:device:home:Foyer_Keypad:keypadButtonC" }
Switch keypadSwitchD "Living Room" { channel="insteon:device:home:Foyer_Keypad:keypadButtonD" }
Switch keypadSwitchE "Dining Room" { channel="insteon:device:home:Foyer_Keypad:keypadButtonE" }
Switch keypadSwitchF "Kitchen" { channel="insteon:device:home:Foyer_Keypad:keypadButtonF" }
Switch keypadSwitchG "Basement Stairwell" { channel="insteon:device:home:Foyer_Keypad:keypadButtonG" }
Switch keypadSwitchH "All Off" { channel="insteon:device:home:Foyer_Keypad:keypadButtonH" }
Number keypadSwitchHManual "All Off" { channel="insteon:device:home:Foyer_Keypad:manualChangeButtonH" }
This is how I had it configured and working in OH2 for reference:
Dimmer DrivewayLights "Driveway Lights [%.0f]" (ExteriorDimmers,Persistant) {insteonplm="2b.98.42:F00.00.16#loaddimmer"}
Switch keypadSwitchB "Foyer" (Persistant){insteonplm="2b.98.42:F00.00.16#keypadbuttonB,group=0xf2,related=2b.da.30"}
Switch keypadSwitchC "All Outside" (Persistant){insteonplm="2b.98.42:F00.00.16#keypadbuttonC,group=0xf3"}
Switch keypadSwitchD "Living Room" (Persistant){insteonplm="2b.98.42:F00.00.16#keypadbuttonD,group=0xf4"}
Switch keypadSwitchE "Dining Room" (Persistant){insteonplm="2b.98.42:F00.00.16#keypadbuttonE,group=0xf5,related=30.b2.0a"}
Switch keypadSwitchF "Kitchen" (Persistant){insteonplm="2b.98.42:F00.00.16#keypadbuttonF,group=0xf6,related=30.9c.50"}
Switch keypadSwitchG "Basement Stairwell" (Persistant){insteonplm="2b.98.42:F00.00.16#keypadbuttonG,group=0xf7"}
Switch keypadSwitchH "All Off" (Persistant){insteonplm="2b.98.42:F00.00.16#keypadbuttonH,group=0xf8"}
As always any help is appreciated
