So I’m working with the Insteon PLM 1.11 Snapshot binding and I have it loading just fine. I created a file my_devices.xml where I’m adding some features to the keypads that I use. I’ll copy it below:
<device productKey="F00.00.15">
<model>2334-232</model>
<description>Keypad Dimmer Switch, 6-Button </description>
<feature name="loaddimmer">LoadDimmerButton</feature>
<feature name="rampdimmer">LoadDimmerRamp</feature>
<feature name="manualchange">ManualChange</feature>
<feature name="fastonoff">LoadDimmerFastOnOff</feature>
<feature_group name="button_group" type="KeyPadButtonGroup">
<feature name="keypadbuttonA">KeyPadButton3</feature>
<feature name="keypadbuttonB">KeyPadButton4</feature>
<feature name="keypadbuttonC">KeyPadButton5</feature>
<feature name="keypadbuttonD">KeyPadButton6</feature>
</feature_group>
<feature_group name="fastonoff_button_group" type="FastOnOffButtonGroup">
<feature name="fastonoffbuttonA">FastOnOffButton3</feature>
<feature name="fastonoffbuttonB">FastOnOffButton4</feature>
<feature name="fastonoffbuttonC">FastOnOffButton5</feature>
<feature name="fastonoffbuttonD">FastOnOffButton6</feature>
</feature_group>
<feature_group name="manualchange_button_group" type="ManualChangeButtonGroup">
<feature name="manualchangebuttonA">ManualChangeButton3</feature>
<feature name="manualchangebuttonB">ManualChangeButton4</feature>
<feature name="manualchangebuttonC">ManualChangeButton5</feature>
<feature name="manualchangebuttonD">ManualChangeButton6</feature>
</feature_group>
<feature name="lastheardfrom">GenericLastTime</feature>
</device>
<device productKey="F00.00.16">
<description>Keypad Dimmer Switch, 8-Button </description>
<feature name="keypadbuttonB">KeyPadButton2</feature>
<feature name="keypadbuttonC">KeyPadButton3</feature>
<feature name="keypadbuttonD">KeyPadButton4</feature>
<feature name="keypadbuttonE">KeyPadButton5</feature>
<feature name="keypadbuttonF">KeyPadButton6</feature>
<feature name="keypadbuttonG">KeyPadButton7</feature>
<feature name="keypadbuttonH">KeyPadButton8</feature>
</feature_group>
<feature name="fastonoffbuttonB">FastOnOffButton2</feature>
<feature name="fastonoffbuttonC">FastOnOffButton3</feature>
<feature name="fastonoffbuttonD">FastOnOffButton4</feature>
<feature name="fastonoffbuttonE">FastOnOffButton5</feature>
<feature name="fastonoffbuttonF">FastOnOffButton6</feature>
<feature name="fastonoffbuttonG">FastOnOffButton7</feature>
<feature name="fastonoffbuttonH">FastOnOffButton8</feature>
</feature_group>
<feature name="manualchangebuttonB">ManualChangeButton2</feature>
<feature name="manualchangebuttonC">ManualChangeButton3</feature>
<feature name="manualchangebuttonD">ManualChangeButton4</feature>
<feature name="manualchangebuttonE">ManualChangeButton5</feature>
<feature name="manualchangebuttonF">ManualChangeButton6</feature>
<feature name="manualchangebuttonG">ManualChangeButton7</feature>
<feature name="manualchangebuttonH">ManualChangeButton8</feature>
</feature_group>
</device>
When I start the system I get the following error:
15:02:04.717 [ERROR] [g.insteonplm.InsteonPLMActiveBinding] - error reading additional devices from /var/lib/openhab2/insteonplm/my_devices.xml
org.xml.sax.SAXParseException; lineNumber: 29; columnNumber: 2; The markup in the document following the root element must be well-formed.
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:257)[:1.8.0_144]
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:339)[:1.8.0_144]
at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java:121)[:1.8.0_144]
at org.openhab.binding.insteonplm.internal.device.DeviceTypeLoader.loadDeviceTypesXML(DeviceTypeLoader.java:75)[239:org.openhab.binding.insteonplm:1.10.0]
at org.openhab.binding.insteonplm.internal.device.DeviceTypeLoader.loadDeviceTypesXML(DeviceTypeLoader.java:98)[239:org.openhab.binding.insteonplm:1.10.0]
at org.openhab.binding.insteonplm.InsteonPLMActiveBinding.processBindingConfiguration(InsteonPLMActiveBinding.java:301)[239:org.openhab.binding.insteonplm:1.10.0]
at org.openhab.binding.insteonplm.InsteonPLMActiveBinding.updated(InsteonPLMActiveBinding.java:272)[239:org.openhab.binding.insteonplm:1.10.0]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1461)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1417)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)[3:org.apache.felix.configadmin:1.8.12]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_144]
When I delete device F00.00.16 I no longer get the error but as soon as I add it or any other device the error returns. What I copied above is the entirety of the file I created. Could anyone point me to where I’m formatting this file wrong?
Thanks for the help,
Matt
