Insteon Binding on 3.0.0-snapshot
Has anyone had any success running the Insteon binding with the latest 3.0.0-snapshot. I am able to create the Bridge and Device things and bind the channels to Items. But the items do not appear to receive updates.
It appears that the method:
@Override
public void channelLinked(ChannelUID channelUID)
Is not getting called in the ThingHandler for Insteon devices.
You can verify this by running the console command insteon display_channels. The command will return the list of channels that are linked. With OH3 the list is blank and with OH2 it will return a list of linked channels.
You’ve ran into:
I grabbed the latest 3.0.0-snapshot and verified that the Insteon binding now works with OH 3. Thank you @wborn for fixing this.
I still have the problem. It works after the addon is initially installed but after a period of time I begin to see:
2020-10-08 14:16:40.602 [WARN ] [ding.insteon.internal.InsteonBinding] - unable to find binding config for channel insteon:device:insteonhub:XXXXXX:dimmer
Neither restarting Openhab nor bundle:restart from the console seem to fix it
I am seeing the same thing on restart of OH3, and created https://github.com/openhab/openhab-core/issues/1707 for it.
@finleyg this has been fixed in the latest snapshot build.
Thanks Rob!
