Insteon broke on upgrade to 4.3
I have uploaded a build compiled for 4.3 including the changes above and the fix for the bug you reported in the other post.
If you are deploying the jar file, you need to install the transport serial feature via the console:
feature:install openhab-transport-serial
This has been fixed and you should be able to use the way you originally defined your scenes including the custom labels.
