@ranielsen Here is what I get:
Display Channels
insteon:device:26B61C:beep feature = beep parameters = {}
insteon:device:26B61C:dimmer feature = dimmer parameters = {}
insteon:device:26B61C:fastOnOff feature = fastonoff parameters = {}
insteon:device:26B61C:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:26B61C:ledOnOff feature = ledonoff parameters = {}
insteon:device:26B61C:manualChange feature = manualchange parameters = {}
insteon:device:31D6C4:batteryLevel feature = data parameters = {field=battery_level}
insteon:device:31D6C4:contact feature = contact parameters = {}
insteon:device:31D6C4:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:31D6C4:lightLevel feature = data parameters = {field=light_level}
insteon:device:31D6C4:lightLevelAboveThreshold feature = lightlevelabovethreshold parameters = {}
insteon:device:31D6C4:lowBattery feature = lowbattery parameters = {}
insteon:device:3CF6C0:beep feature = beep parameters = {}
insteon:device:3CF6C0:dimmer feature = dimmer parameters = {}
insteon:device:3CF6C0:fastOnOff feature = fastonoff parameters = {}
insteon:device:3CF6C0:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:3CF6C0:ledBrightness feature = ledbrightness parameters = {}
insteon:device:3CF6C0:ledOnOff feature = ledonoff parameters = {}
insteon:device:3CF6C0:manualChange feature = manualchange parameters = {}
insteon:device:3CF6C0:onLevel feature = onlevel parameters = {}
insteon:device:3CF6C0:rampRate feature = ramprate parameters = {}
insteon:device:3FF4AC:contact feature = contact parameters = {}
insteon:device:3FF4AC:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:4AE52D:beep feature = beep parameters = {}
insteon:device:4AE52D:dimmer feature = dimmer parameters = {}
insteon:device:4AE52D:fastOnOff feature = fastonoff parameters = {}
insteon:device:4AE52D:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:4AE52D:ledBrightness feature = ledbrightness parameters = {}
insteon:device:4AE52D:ledOnOff feature = ledonoff parameters = {}
insteon:device:4AE52D:manualChange feature = manualchange parameters = {}
insteon:device:4AE52D:onLevel feature = onlevel parameters = {}
insteon:device:4AE52D:rampRate feature = ramprate parameters = {}
insteon:device:4AF1D5:beep feature = beep parameters = {}
insteon:device:4AF1D5:dimmer feature = dimmer parameters = {}
insteon:device:4AF1D5:fastOnOff feature = fastonoff parameters = {}
insteon:device:4AF1D5:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:4AF1D5:ledBrightness feature = ledbrightness parameters = {}
insteon:device:4AF1D5:ledOnOff feature = ledonoff parameters = {}
insteon:device:4AF1D5:manualChange feature = manualchange parameters = {}
insteon:device:4AF1D5:onLevel feature = onlevel parameters = {}
insteon:device:4AF1D5:rampRate feature = ramprate parameters = {}
insteon:device:4F7ADD:beep feature = beep parameters = {}
insteon:device:4F7ADD:dimmer feature = dimmer parameters = {}
insteon:device:4F7ADD:fastOnOff feature = fastonoff parameters = {}
insteon:device:4F7ADD:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:4F7ADD:ledBrightness feature = ledbrightness parameters = {}
insteon:device:4F7ADD:ledOnOff feature = ledonoff parameters = {}
insteon:device:4F7ADD:manualChange feature = manualchange parameters = {}
insteon:device:4F7ADD:onLevel feature = onlevel parameters = {}
insteon:device:4F7ADD:rampRate feature = ramprate parameters = {}
insteon:device:4FC447:beep feature = beep parameters = {}
insteon:device:4FC447:dimmer feature = dimmer parameters = {}
insteon:device:4FC447:fastOnOff feature = fastonoff parameters = {}
insteon:device:4FC447:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:4FC447:ledBrightness feature = ledbrightness parameters = {}
insteon:device:4FC447:ledOnOff feature = ledonoff parameters = {}
insteon:device:4FC447:manualChange feature = manualchange parameters = {}
insteon:device:4FC447:onLevel feature = onlevel parameters = {}
insteon:device:4FC447:rampRate feature = ramprate parameters = {}
insteon:device:4FC493:beep feature = beep parameters = {}
insteon:device:4FC493:dimmer feature = dimmer parameters = {}
insteon:device:4FC493:fastOnOff feature = fastonoff parameters = {}
insteon:device:4FC493:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:4FC493:ledBrightness feature = ledbrightness parameters = {}
insteon:device:4FC493:ledOnOff feature = ledonoff parameters = {}
insteon:device:4FC493:manualChange feature = manualchange parameters = {}
insteon:device:4FC493:onLevel feature = onlevel parameters = {}
insteon:device:4FC493:rampRate feature = ramprate parameters = {}
insteon:device:4FC7CE:beep feature = beep parameters = {}
insteon:device:4FC7CE:dimmer feature = dimmer parameters = {}
insteon:device:4FC7CE:fastOnOff feature = fastonoff parameters = {}
insteon:device:4FC7CE:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:4FC7CE:ledBrightness feature = ledbrightness parameters = {}
insteon:device:4FC7CE:ledOnOff feature = ledonoff parameters = {}
insteon:device:4FC7CE:manualChange feature = manualchange parameters = {}
insteon:device:4FC7CE:onLevel feature = onlevel parameters = {}
insteon:device:4FC7CE:rampRate feature = ramprate parameters = {}
insteon:device:538E0F:beep feature = beep parameters = {}
insteon:device:538E0F:dimmer feature = dimmer parameters = {}
insteon:device:538E0F:fastOnOff feature = fastonoff parameters = {}
insteon:device:538E0F:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:538E0F:ledBrightness feature = ledbrightness parameters = {}
insteon:device:538E0F:ledOnOff feature = ledonoff parameters = {}
insteon:device:538E0F:manualChange feature = manualchange parameters = {}
insteon:device:538E0F:onLevel feature = onlevel parameters = {}
insteon:device:538E0F:rampRate feature = ramprate parameters = {}
insteon:device:5415D1:beep feature = beep parameters = {}
insteon:device:5415D1:fastOnOff feature = fastonoff parameters = {}
insteon:device:5415D1:fastOnOffButtonB feature = fastonoffbuttonb parameters = {}
insteon:device:5415D1:fastOnOffButtonC feature = fastonoffbuttonc parameters = {}
insteon:device:5415D1:fastOnOffButtonD feature = fastonoffbuttond parameters = {}
insteon:device:5415D1:fastOnOffButtonE feature = fastonoffbuttone parameters = {}
insteon:device:5415D1:fastOnOffButtonF feature = fastonoffbuttonf parameters = {}
insteon:device:5415D1:fastOnOffButtonG feature = fastonoffbuttong parameters = {}
insteon:device:5415D1:fastOnOffButtonH feature = fastonoffbuttonh parameters = {}
insteon:device:5415D1:keypadButtonB feature = keypadbuttonb parameters = {}
insteon:device:5415D1:keypadButtonC feature = keypadbuttonc parameters = {}
insteon:device:5415D1:keypadButtonD feature = keypadbuttond parameters = {}
insteon:device:5415D1:keypadButtonE feature = keypadbuttone parameters = {}
insteon:device:5415D1:keypadButtonF feature = keypadbuttonf parameters = {}
insteon:device:5415D1:keypadButtonG feature = keypadbuttong parameters = {}
insteon:device:5415D1:keypadButtonH feature = keypadbuttonh parameters = {}
insteon:device:5415D1:lastHeardFrom feature = lastheardfrom parameters = {}
insteon:device:5415D1:ledBrightness feature = ledbrightness parameters = {}
insteon:device:5415D1:ledOnOff feature = ledonoff parameters = {}
insteon:device:5415D1:loadDimmer feature = loaddimmer parameters = {}
insteon:device:5415D1:manualChange feature = manualchange parameters = {}
insteon:device:5415D1:manualChangeButtonB feature = manualchangebuttonb parameters = {}
insteon:device:5415D1:manualChangeButtonC feature = manualchangebuttonc parameters = {}
insteon:device:5415D1:manualChangeButtonD feature = manualchangebuttond parameters = {}
insteon:device:5415D1:manualChangeButtonE feature = manualchangebuttone parameters = {}
insteon:device:5415D1:manualChangeButtonF feature = manualchangebuttonf parameters = {}
insteon:device:5415D1:manualChangeButtonG feature = manualchangebuttong parameters = {}
insteon:device:5415D1:manualChangeButtonH feature = manualchangebuttonh parameters = {}
insteon:device:5415D1:onLevel feature = onlevel parameters = {}
insteon:device:5415D1:rampDimmer feature = rampdimmer parameters = {}
insteon:device:5415D1:rampRate feature = ramprate parameters = {}
Display devices:
insteon:device:26B61C address = 26.B6.1C productKey = F00.00.19 channels = beep, fastOnOff, lastHeardFrom, ledOnOff, dimmer, manualChange
insteon:device:31D6C4 address = 31.D6.C4 productKey = 0x00004A channels = contact, lastHeardFrom, lowBattery, batteryLevel, lightLevel, lightLevelAboveThreshold
insteon:device:3CF6C0 address = 3C.F6.C0 productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
insteon:device:3FF4AC address = 3F.F4.AC productKey = F00.00.0A channels = contact, lastHeardFrom
insteon:device:4AE52D address = 4A.E5.2D productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
insteon:device:4AF1D5 address = 4A.F1.D5 productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
insteon:device:4F7ADD address = 4F.7A.DD productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
insteon:device:4FC447 address = 4F.C4.47 productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
insteon:device:4FC493 address = 4F.C4.93 productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
insteon:device:4FC7CE address = 4F.C7.CE productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
insteon:device:538E0F address = 53.8E.0F productKey = F00.00.01 channels = beep, onLevel, fastOnOff, ledBrightness, lastHeardFrom, ledOnOff, rampRate, dimmer, manualChange
insteon:device:5415D1 address = 54.15.D1 productKey = F00.00.16 channels = beep, onLevel, fastOnOffButtonD, fastOnOffButtonE, fastOnOffButtonB, fastOnOffButtonC, manualChangeButtonE, manualChangeButtonD, manualChangeButtonG, manualChangeButtonF, manualChangeButtonC, manualChangeButtonB, fastOnOff, ledBrightness, lastHeardFrom, loadDimmer, manualChangeButtonH, fastOnOffButtonH, fastOnOffButtonF, fastOnOffButtonG, ledOnOff, rampRate, rampDimmer, keypadButtonD, keypadButtonE, keypadButtonB, keypadButtonC, manualChange, keypadButtonH, keypadButtonF, keypadButtonG
