So I bought 2xInsteon Garage Door & Status kits over 5 years ago. Never installed them using my old Insteon setup. But I am FINALLY getting around to it with my OpenHab setup at our new home.
Before going out into the Garage I decided to “Play” with my new toy in my Home Office - where it is nice and warm.
I was able to pair the I/O Linc in both directions with my USB Modem. Device showed up in OpenHab in Things as a “SensorsActuators_IOLinc” and I added is as “Equipment” type under my new “Garage” location - called “Garage Door Opener”. I then added the “Contact Sensor”, “Last Heard From”, and “Switch” as Points under that Equipment.
Since this was a Garage Door and Status “Kit” - the Magnetic Sensor (for Door position) and the pigtail that gets wired to the “Momentary Push button Input” on my Garage door opener were already wired up to the IOLinc. The Magnetic sensor is wired to “Gnd” and “S”, and the pigtail is wired to “NO” and “C”.
So far so good.
I expected the Magnetic sensor to interact with the “Contact Sensor” status in OH to show the position of the Garage Door. I also assumed the “Swich” would interact with the Pigtail - and be NO and only close for a second or 2 then I manually toggle it from OH.
Well that is NOT what I am experiencing….
The “Contact Sensor” indication is ALWAYS shown as “Open” and has not changed in any of my testing.
The “Switch” is shown as “ON” in OH and the LED on the IOLinc is OFF.
IF I put the magnet near the contact sensor - the indication of the “Switch” moves to “OFF” in OH and the GREEN LED on the IOLinc illuminates.
IF move the magnet away from the sensor - the “Switch” indication in OH immediately go back to “ON” and the LED on the IOLinc turns off.
In OH with the Switch showing ON - I then toggle it in OH to OFF.
Switch indication in OH goes OFF - no relay sound in IOLinc.
In OH with the Switch showing OFF - I then toggle it in OH to ON.
I hear the relay click in the IOLinc - LED on the side of IOLinc goes ON for about 2 seconds - Second Click - LED on side goes OFF.
Seems to me like something is “crossed up” in the OH Binding for these indications and controls.
Anyone have any thoughts ?
