Insteon Hidden Door Sensors can be configured in 2 different modes. ‘1 node’ or ‘2 nodes’
- In ‘1 node’ mode a
0x11
ON command is sent when the door is opened and a0x13
OFF command is sent when the door is closed, both on group 1. - In ‘2 nodes’ mode a
0x11
ON command is sent on group 1 when the door is opened and a0x11
ON command is sent on group 2 when the door is closed.
With no modification the current Insteon PLM code for the Hidden Door Sensor will not work as desired since there is never a 0x13
sent on group one, so even with modification of the features/devices xml file to monitor group 2, only the first message on each group is accepted and all others are ignored as duplicates.
So, I decided to modify the Binding Code to add a new MessageHandler:
public static class OpenedOrClosedSleepingContactHandler extends MessageHandler {
OpenedOrClosedSleepingContactHandler(DeviceFeature p) {
super(p);
@Override
public void handleMessage(int group, byte cmd1, Msg msg, DeviceFeature f, String fromPort) {
try {
byte cmd2 = msg.getByte("command2");
switch (cmd1) {
case 0x11: // ON
switch (cmd2) {
case 0x01:
m_feature.publish(OpenClosedType.OPEN, StateChangeType.CHANGED);
sendExtendedQuery(f, (byte) 0x2e, (byte) 00);
break;
case 0x02:
m_feature.publish(OpenClosedType.CLOSED, StateChangeType.CHANGED);
break;
default: // do nothing
break;
break;
case 0x13: // OFF
switch (cmd2) {
case 0x01: // Group 1
break;
break;
break;
} catch (FieldException e) {
logger.debug("{} no cmd2 found, dropping msg {}", nm(), msg);
return;
Please note:
- I am a .Net developer so please excuse any Java Faux pas
- All of my Hidden Door Sensors are in the 2 nodes configuration so I haven’t tested the code to see if it works in the 1 node config.
My plan was to make this handler work for both node configurations but at the moment I have a new feature and device type to make this work that I am using for all of my (3) hidden door sensors:
Feature:
<!-- Hidden Door Sensor (Two Nodes) -->
<feature name="HiddenDoorSensorContact2Nodes">
<message-dispatcher>DefaultDispatcher</message-dispatcher>
<message-handler cmd="0x03">NoOpMsgHandler</message-handler>
<message-handler cmd="0x11">OpenedOrClosedSleepingContactHandler</message-handler>
<message-handler cmd="0x13">OpenedOrClosedSleepingContactHandler</message-handler>
<message-handler cmd="0x19">NoOpMsgHandler</message-handler>
<message-handler cmd="0x2e">NoOpMsgHandler</message-handler>
<command-handler command="OnOffType">NoOpCommandHandler</command-handler>
<poll-handler>NoPollHandler</poll-handler>
</feature>
Device:
<device productKey="F00.00.03">
<model>2845-222</model>
<description>Hidden Door Sensor (Two Nodes)</description>
<feature name="contact2nodes">HiddenDoorSensorContact2Nodes</feature>
<feature name="data">HiddenDoorSensorData</feature>
<feature name="lastheardfrom">GenericLastTime</feature>
</device>
Anyway, this all seems to work fine as long as I open and then close the door with a significant delay between the open and the close. If the door is opened and then closed too quickly, then OH never gets the CLOSED
event.
I dug around in the InsteonPLM.log file and I have found what could be the problem.
2017-06-05 12:33:57 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:2C.74.E7|toAddress:00.00.01|messageFlags:0xCB=ALL_LINK_BROADCAST:3:2|command1:0x11|command2:0x01|
2017-06-05 12:33:57 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:75) - all link message: IN:Cmd:0x50|fromAddress:2C.74.E7|toAddress:00.00.01|messageFlags:0xCB=ALL_LINK_BROADCAST:3:2|command1:0x11|command2:0x01|
2017-06-05 12:33:57 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:77) - all link message is no duplicate: true/true
2017-06-05 12:33:57 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:79) - 2C.74.E7:HiddenDoorSensorData->NoOpMsgHandler cmd1:0x11 group 1/1:IN:Cmd:0x50|fromAddress:2C.74.E7|toAddress:00.00.01|messageFlags:0xCB=ALL_LINK_BROADCAST:3:2|command1:0x11|command2:0x01|
2017-06-05 12:33:57 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:79) - 2C.74.E7:HiddenDoorSensorContact2Nodes->OpenedOrClosedSleepingContactHandler cmd1:0x11 group 1/-1:IN:Cmd:0x50|fromAddress:2C.74.E7|toAddress:00.00.01|messageFlags:0xCB=ALL_LINK_BROADCAST:3:2|command1:0x11|command2:0x01|
2017-06-05 12:33:57 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 2C.74.E7:HiddenDoorSensorContact2Nodes publishing: OPEN
2017-06-05 12:33:57 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 2C.74.E7:GenericLastTime publishing: 2017-06-05T12:33:57
2017-06-05 12:33:57 org.openhab.binding.insteonplm.internal.device.InsteonDevice.processRequestQueue(InsteonDevice.java:451) - still waiting for query reply from 2C.74.E7 for another 1595 usec
2017-06-05 12:33:57 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:2C.74.E7|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x11|command2:0x01|
2017-06-05 12:33:57 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:75) - all link message: IN:Cmd:0x50|fromAddress:2C.74.E7|toAddress:00.00.01|messageFlags:0xC7=ALL_LINK_BROADCAST:3:1|command1:0x11|command2:0x01|
2017-06-05 12:33:57 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:2C.74.E7|toAddress:44.31.A5|messageFlags:0x41=ALL_LINK_CLEANUP:1:0|command1:0x11|command2:0x01|
2017-06-05 12:33:57 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:75) - all link message: IN:Cmd:0x50|fromAddress:2C.74.E7|toAddress:44.31.A5|messageFlags:0x41=ALL_LINK_CLEANUP:1:0|command1:0x11|command2:0x01|
2017-06-05 12:33:59 org.openhab.binding.insteonplm.internal.device.InsteonDevice.processRequestQueue(InsteonDevice.java:454) - gave up waiting for query reply from device 2C.74.E7
2017-06-05 12:33:59 org.openhab.binding.insteonplm.internal.device.InsteonDevice.processRequestQueue(InsteonDevice.java:459) - qe taken off direct: HiddenDoorSensorContact2Nodes(1:1:5) OUT:Cmd:0x62|toAddress:2C.74.E7|messageFlags:0x1F=DIRECT:3:3|command1:0x2E|command2:0x00|userData1:0x00|userData2:0x00|userData3:0x00|userData4:0x00|userData5:0x00|userData6:0x00|userData7:0x00|userData8:0x00|userData9:0x00|userData10:0x00|userData11:0x00|userData12:0x00|userData13:0x00|userData14:0xD2|
2017-06-05 12:33:59 org.openhab.binding.insteonplm.internal.device.InsteonDevice.processRequestQueue(InsteonDevice.java:479) - next request queue processed in 2000 msec, quiettime = 2000
2017-06-05 12:33:59 org.openhab.binding.insteonplm.internal.driver.Port$IOStreamWriter.run(Port.java:415) - writing (500): OUT:Cmd:0x62|toAddress:2C.74.E7|messageFlags:0x1F=DIRECT:3:3|command1:0x2E|command2:0x00|userData1:0x00|userData2:0x00|userData3:0x00|userData4:0x00|userData5:0x00|userData6:0x00|userData7:0x00|userData8:0x00|userData9:0x00|userData10:0x00|userData11:0x00|userData12:0x00|userData13:0x00|userData14:0xD2|
2017-06-05 12:34:01 org.openhab.binding.insteonplm.internal.device.RequestQueueManager$RequestQueueReader.run(RequestQueueManager.java:137) - device queue for 2C.74.E7 is empty!
2017-06-05 12:34:02 org.openhab.binding.insteonplm.InsteonPLMActiveBinding$PortListener.msg(InsteonPLMActiveBinding.java:591) - got msg: IN:Cmd:0x50|fromAddress:2C.74.E7|toAddress:44.31.A5|messageFlags:0x4B=ALL_LINK_CLEANUP:3:2|command1:0x11|command2:0x02|
2017-06-05 12:34:02 org.openhab.binding.insteonplm.internal.device.MessageDispatcher.handleAllLinkMessage(MessageDispatcher.java:75) - all link message: IN:Cmd:0x50|fromAddress:2C.74.E7|toAddress:44.31.A5|messageFlags:0x4B=ALL_LINK_CLEANUP:3:2|command1:0x11|command2:0x02|
2017-06-05 12:34:02 org.openhab.binding.insteonplm.internal.device.DeviceFeature.publish(DeviceFeature.java:321) - 2C.74.E7:GenericLastTime publishing: 2017-06-05T12:34:02
It looks like the binding is seeing the OPEN (0x11 on group 1) as an ALL_LINK_BROADCAST but then when the CLOSE (0x11 on group 2) comes in, the binding is seeing it as and ALL_LINK_CLEANUP so therefore not interpreting it as a command and not triggering an OH event.
I could be way off on my theory as I’m still trying to learn but any ideas/advice would be appreciated.
