Hello, I am having trouble with Insteon devices on openHAB. According to the log, it appears that openHAB has no route to the Insteon hub. This issue just showed up 2 days ago with no changes to either openHAB or Insteon.
So I did another full restart of my network and the modem linked up correctly and everything is functional once again. I will continue to monitor this behavior and see if it persists.
This appears to be an issue with your router. This is what the documentation for the java.net.NoRouteToHostException exception:
Signals that an error occurred while attempting to connect a socket to a remote address and port. Typically, the remote host cannot be reached because of an intervening firewall, or if an intermediate router is down.
I also see you are using the insteonplm binding, it is no longer supported and has been replaced by the Insteon binding
I was having difficulty uninstalling the insteonplm and installing your new insteon binding so I just did a full clean install of OpenHAB2. I’m following the documentation, however, I’m a little uncertain of the preferred way to configure the devices. I was able to quickly utilize HABmin and get the devices to work. In the past I used the command line and manually edited the things/items/sitemap files. Where I’m a bit confused is, idk where the HABmin file locations are for these files (to manually edit)!? I manually added these files to the path /etc/openhab2/ but it seems to conflict with the HABmin configuration. Any advice would be helpful.
