Insteon Hub openHAB latest version trouble
Just got an instance of openHAB 1.8.2 running in Ubuntu 14.04 and searched for the best ways to integrate an existing Insteon Hub v2 2245. I have added the add-on, configured the Insteon PLM in the openhab.cfg and added the detailed logging into the XML file and I am certain I have done something wrong. The openHAB doesn’t even attempt to talk to the hub that I can see.
under var/log/openhab I see the following, but it remains empty:
rw-r–r-- 1 openhab openhab 0 May 18 11:51 insteonplm.log
The entry in my openhab.cfg for the Hub itself…
############################### Insteon PLM Binding ###################################
# The insteon PLM controller port, one for each modem or hub.
# You can have multiple ports, but that has never been tested, use at your own peril.
# examples of valid port configurations for serial or usb modems:
# Linux, with serial port symlinked to /dev/insteon:
# insteonplm:port_0=/dev/insteon
# Linux, with plain old serial modem:
# insteonplm:port_0=/dev/ttyS0
# Linux, with usb based PLM modem:
# insteonplm:port_0=/dev/ttyUSB0
# Windows, with serial/usb modem on COM1:
# insteonplm:port_0=COM1
# to connect to an Insteon Hub2 (the 2014 version) on port 25105 with
# a poll interval of 1000ms = 1sec, use the following line. Use the login
# and password that is printed on the label on the bottom of the hub,
# NOT the Insteon online login and password!
insteonplm:port_0=/hub2/USER:PASS@10.1.1.66:25105,poll_time=1000
This has the actual username and password entered from the bottom of the hub…
# to connect to the raw tcp feed on an older Insteon Hub (pre 2014 version) on port 9761
# insteonplm:port_0=/hub/localhost:9761
# Poll interval (optional, in milliseconds, defaults to 300000).
# Poll too often and you will overload the insteon network, leading to sluggish
# or no response when trying to send messages to devices. Poll too rarely and it’ll
# take a long time to establish the correct state of all devices.
# The default poll interval of 300s has been tested and found to be a good
# compromise in a configuration of about 110 switches/dimmers.
insteonplm:poll_interval=300000
# If the modem database download times out prematurely (while the download is
# still making progress), bump this parameter. Timeout is in milliseconds, default is 120000.
# You should not have to adjust this parameter. Please post on the openhab forum if you do
# have to bump it.
And I have confirmed that it is indeed reachable inside my network at the supplied credentials.
I have added, or tried to add a few switches in the items folder…
Switch breakfastbar “BreakFast Bar” {insteonplm=“23.60.CE:F00.00.01#switch”}
Switch diningroom “Dining Room” {insteonplm=“26.77.12:F00.00.01#switch”}
Switch foyerlamp “Foyer Lamp” {insteonplm=“23.62.DE:F00.00.01#switch”}
Switch hearthroom “Hearth Room” {insteonplm=“23.62.DC:F00.00.01#switch”}
And then added a single switch (the breakfast bar one) to see if I could control it.
Frame label=“Lights” {
Switch item=breakfastbar label=“Breakfast Bar”
I know I am missing something…but I have searched and it seems I may be missing something easy or not understanding the flow of how objects and items are called. I have searched on the forums and gotten bits and pieces but am brand new and just seeing if this is an option for me.
Thanks for any help.
Did you copy the right addon to addons folder (there are two insteon addons)?
I did, and after rebooting, actually got it working however, it seems I have the items messed up somehow. The log now shows:
2016-05-18 14:01:03 INFO o.o.b.i.InsteonPLMActiveBinding[:621]- device 23.62.DC found in the modem database, but is not configured as an item and the modem controls groups [0x00,0x0A,0x0B] and responds to groups [0x01].
But in the items file…
So clearly, I have something mis-defined but am closer…
Sorry if it’s bad etiquette to revive this old topic.
Just found this thread today, and I’m having exactly the same problem as the original poster. I have the items listed in .items file, but the log says "device found in modem database, but is not configured as an item (etc…)"
Did you (fastattack, the OP) ever figure out what the issue was, to get it to recognize the items in the .items file?
Thanks,
Sean
