I have a system with Insteon Dimmer KeyPads and the USB PLM. I’m trying to set things up so that the various Insteon devices are minimally connected together - just major functions communicated directly. My Openhabian based OpenHab system then uses rules to add more functionality to the system. I have a few weirdnesses in my setup, currently focused on the dining room dimmer keypad.
- First, keypadButtons G and H trigger exactly as expected. I’m including their code here just for a reference point.
rule "DiningRoomGButton"
Item diningroomG received update
logInfo( "rules", "diningroomG rule received. diningroomG State: [{}] ", diningroomG.state );
rule "DiningRoomHButton"
Item diningroomH received update
logInfo( "rules", "diningroomH rule received. diningroomH State: [{}] ", diningroomH.state );
- keypadButtonB never triggers rules. This button is configured to directly control a switchlinc, and that works fine. But the rule never actually triggers as evidenced by the lack of a log entry.
// turn on the front porch light whenever the hall light is turned on
rule "DiningRoomBButton"
Item diningroomB received update
logInfo( "rules", "diningroomB rule received. diningroomB State: [{}]", diningroomB.state );
if (diningroomB.state == ON) {
frontporch.sendCommand(100);
} else {
frontporch.sendCommand(0);
- keypadButtonE actually does work. But strangely, whenever it does trigger, G & H (above) also trigger. Other than that, keypadButtonE works exactly as expected.
rule "DiningRoomEButton"
Item diningroomE received update
logInfo( "rules", "diningroomE rule received. diningroomE State: [{}] ", diningroomE.state );
if (diningroomE.state == ON) {
ChristmasTree.sendCommand(ON);
ChristmasWindow.sendCommand(ON);
// ChristmasOutside.sendCommand(ON);
} else if (diningroomE.state == OFF) {
ChristmasTree.sendCommand(OFF);
ChristmasWindow.sendCommand(OFF);
// ChristmasOutside.sendCommand(OFF);
Here are the item definitions of each of these items:
Switch diningroomB "Front Porch Light Switch" (Lights) [ "Lighting" ] {channel="insteon:device:home:2a9abd:keypadButtonB", homekit="Lighting.OnState"}
Switch diningroomC "Living Room Light Switch" (Lights) [ "Lighting" ] {channel="insteon:device:home:2a9abd:keypadButtonC", homekit="Lighting.OnState"}
Switch diningroomD "Office Light Switch" (Lights) [ "Lighting" ] {channel="insteon:device:home:2b9abd:keypadButtonD", homekit="Lighting.OnState"}
Switch diningroomF "Kids Room Switch" (Lights) [ "Lighting" ] {channel="insteon:device:home:2b9abd:keypadButtonF", homekit="Lighting.OnState"}
// E G & H aren't connected by switch to anything and are free for openhab scripting. they also won't do anything if openhab is down
Switch diningroomE "Christmas Light Switch" (Lights) [ "Lighting" ] {channel="insteon:device:home:2b9abd:keypadButtonE", homekit="Lighting.OnState"}
Switch diningroomG "Music Play" (Lights) [ "Lighting" ] {channel="insteon:device:home:2b9abd:keypadButtonG", homekit="Lighting.OnState"}
Switch diningroomH "Playlist" (Lights) [ "Lighting" ] {channel="insteon:device:home:2b9abd:keypadButtonH", homekit="Lighting.OnState"}
And here is the things definition for the keypad:
Thing device 2b9b8c [address="2b.9b.8c", productKey="F00.00.16"] {
Channels:
Type loadDimmer : loadDimmer [ group="0xf1" ]
Type keypadButtonB : keypadButtonB [ group="0xf2" ]
Type keypadButtonC : keypadButtonC [ group="0xf3" ]
Type keypadButtonD : keypadButtonD [ group="0xf4" ]
Type keypadButtonE : keypadButtonE [ group="0xf5" ]
Type keypadButtonF : keypadButtonF [ group="0xf6" ]
Type keypadButtonG : keypadButtonG [ group="0xf7" ]
Type keypadButtonH : keypadButtonH [ group="0xf8" ]
I think those group numbers are supposed to be unique to any particular switch… they are not right now… I assume I would have to use InsteonTerminal to program the group (in the responder for each button?) on each of the keypadlinc units. (I have four total.)
I threw the logger into Debug mode for insteon through the CLI and have that below, but it’s like drinking from a firehose and I have no idea really what I’m looking for. The message editor was not pleased with the 200kb of output even a few seconds of debug output created, but let me know if I should get to you in some other way.
I did use InsteonTerminal to confirm that the database has different group numbers for each of the buttons.
InsteonTerminal database output:
>>> drk.getdb()
getting db, be patient!
sent db query msg, incoming records: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68dbbuilder.done() is called
0fff USB modem 3D.99.97 RESP 10101010 group: 00 ON LVL: 254 RMPRT: 28 BUTTON: 1
0ff7 USB modem 3D.99.97 RESP 10100010 group: f2 ON LVL: 255 RMPRT: 31 BUTTON: 2
0fef USB modem 3D.99.97 RESP 10100010 group: f3 ON LVL: 255 RMPRT: 31 BUTTON: 3
0fe7 USB modem 3D.99.97 RESP 10100010 group: f4 ON LVL: 255 RMPRT: 31 BUTTON: 4
0fdf USB modem 3D.99.97 RESP 10100010 group: f5 ON LVL: 255 RMPRT: 31 BUTTON: 5
0fd7 USB modem 3D.99.97 RESP 10100010 group: f6 ON LVL: 255 RMPRT: 31 BUTTON: 6
0fcf USB modem 3D.99.97 RESP 10100010 group: f7 ON LVL: 255 RMPRT: 31 BUTTON: 7
0fc7 USB modem 3D.99.97 RESP 10100010 group: f8 ON LVL: 255 RMPRT: 31 BUTTON: 8
0fbf 2B.9A.21 2B.9A.21 RESP 10101010 group: 02 ON LVL: 254 RMPRT: 28 BUTTON: 1
0fb7 2B.9A.21 2B.9A.21 CTRL 11100010 group: 01 ON LVL: 3 RMPRT: 28 BUTTON: 1
0faf Kids Room Light 20.76.82 RESP 10100010 group: f6 ON LVL: 0 RMPRT: 0 BUTTON: 246
0fa7 Kids Room Light 20.76.82 CTRL 11100010 group: f6 ON LVL: 0 RMPRT: 0 BUTTON: 246
0f9f Kids Room Light 20.76.82 RESP 10101010 group: 01 ON LVL: 255 RMPRT: 28 BUTTON: 6
0f97 Kids Room Light 20.76.82 CTRL 11100010 group: 06 ON LVL: 3 RMPRT: 28 BUTTON: 6
0f8f 20.DC.C9 20.DC.C9 (CTRL) 01100010 group: 07 ON LVL: 3 RMPRT: 31 BUTTON: 7
0f87 20.DC.C9 20.DC.C9 (CTRL) 01100010 group: 02 ON LVL: 3 RMPRT: 31 BUTTON: 2
0f7f 20.DC.C9 20.DC.C9 (RESP) 00100010 group: 11 ON LVL: 255 RMPRT: 31 BUTTON: 4
0f77 20.DC.C9 20.DC.C9 (RESP) 00100010 group: 13 ON LVL: 255 RMPRT: 31 BUTTON: 6
0f6f 20.DC.C9 20.DC.C9 (RESP) 00100010 group: 15 ON LVL: 255 RMPRT: 31 BUTTON: 5
0f67 20.DC.C9 20.DC.C9 (RESP) 00100010 group: 19 ON LVL: 255 RMPRT: 31 BUTTON: 2
0f5f Office Light 1F.EE.1B (CTRL) 01100010 group: 04 ON LVL: 3 RMPRT: 31 BUTTON: 4
0f57 Front Porch Keypad 2B.9B.8C (CTRL) 01100010 group: 07 ON LVL: 3 RMPRT: 31 BUTTON: 7
0f4f Kids Room Light 20.76.82 RESP 10100010 group: 06 ON LVL: 0 RMPRT: 0 BUTTON: 6
0f47 Dining Room Light 1F.ED.6F CTRL 11100010 group: 04 ON LVL: 0 RMPRT: 0 BUTTON: 4
0f3f Front Hall Light 1F.EE.37 (RESP) 00100010 group: 01 ON LVL: 255 RMPRT: 31 BUTTON: 2
0f37 Living Room Top Light 1F.EE.31 (RESP) 00100010 group: 01 ON LVL: 255 RMPRT: 31 BUTTON: 3
0f2f Front Porch Keypad 2B.9B.8C (RESP) 00100010 group: 03 ON LVL: 255 RMPRT: 31 BUTTON: 1
0f27 Front Porch Keypad 2B.9B.8C (RESP) 00100010 group: 04 ON LVL: 255 RMPRT: 31 BUTTON: 3
0f1f Front Porch Keypad 2B.9B.8C (CTRL) 01100010 group: 01 ON LVL: 3 RMPRT: 0 BUTTON: 1
0f17 Front Porch Keypad 2B.9B.8C (CTRL) 01100010 group: 03 ON LVL: 3 RMPRT: 0 BUTTON: 3
0f0f 17.6E.68 17.6E.68 (RESP) 00101010 group: 01 ON LVL: 255 RMPRT: 28 BUTTON: 1
0f07 Dining Room Light 1F.ED.6F (CTRL) 01100010 group: 01 ON LVL: 3 RMPRT: 31 BUTTON: 1
0eff 34.17.49 34.17.49 (CTRL) 01100010 group: 01 ON LVL: 3 RMPRT: 28 BUTTON: 1
0ef7 Front Porch Keypad 2B.9B.8C CTRL 11100010 group: 02 ON LVL: 3 RMPRT: 28 BUTTON: 2
0eef Front Porch Keypad 2B.9B.8C RESP 10100010 group: 02 ON LVL: 3 RMPRT: 28 BUTTON: 2
0ee7 Back Hall Light 20.88.FC (RESP) 00100010 group: 01 ON LVL: 255 RMPRT: 31 BUTTON: 8
0edf Office Light 1F.EE.1B (RESP) 00100010 group: 01 ON LVL: 255 RMPRT: 31 BUTTON: 4
0ed7 Front Porch Keypad 2B.9B.8C (RESP) 00100010 group: 01 ON LVL: 255 RMPRT: 31 BUTTON: 7
0ecf Front Porch Keypad 2B.9B.8C (RESP) 00100010 group: 05 ON LVL: 255 RMPRT: 31 BUTTON: 4
0ec7 Front Porch Keypad 2B.9B.8C (RESP) 00100010 group: 07 ON LVL: 255 RMPRT: 31 BUTTON: 1
0ebf Front Porch Keypad 2B.9B.8C (CTRL) 01100010 group: 04 ON LVL: 3 RMPRT: 0 BUTTON: 4
0eb7 Front Porch Keypad 2B.9B.8C (CTRL) 01100010 group: 07 ON LVL: 3 RMPRT: 0 BUTTON: 7
0eaf Back Hall Light 20.88.FC (CTRL) 01101010 group: 08 ON LVL: 3 RMPRT: 0 BUTTON: 8
0ea7 34.17.49 34.17.49 (RESP) 00101010 group: 00 ON LVL: 0 RMPRT: 28 BUTTON: 3
0e9f Living Room Top Light 1F.EE.31 (CTRL) 01100010 group: 03 ON LVL: 3 RMPRT: 31 BUTTON: 3
0e97 Front Hall Light 1F.EE.37 (CTRL) 01100010 group: 02 ON LVL: 3 RMPRT: 31 BUTTON: 2
0e8f Front Hall Light 1F.EE.37 (CTRL) 01100010 group: 08 ON LVL: 3 RMPRT: 0 BUTTON: 8
0e87 Back Hall Light 20.88.FC (RESP) 00100010 group: 01 ON LVL: 255 RMPRT: 31 BUTTON: 6
0e7f Dining Room Light 1F.ED.6F (RESP) 00100010 group: 01 ON LVL: 255 RMPRT: 31 BUTTON: 4
0e77 Front Hall Light 1F.EE.37 (RESP) 00100010 group: 01 ON LVL: 255 RMPRT: 31 BUTTON: 8
0e6f Office Light 1F.EE.1B (RESP) 00100010 group: 01 ON LVL: 255 RMPRT: 31 BUTTON: 5
0e67 Front Porch Keypad 2B.9B.8C (RESP) 00100010 group: 02 ON LVL: 255 RMPRT: 31 BUTTON: 8
0e5f Front Porch Keypad 2B.9B.8C (RESP) 00100010 group: 03 ON LVL: 255 RMPRT: 31 BUTTON: 4
0e57 Front Porch Keypad 2B.9B.8C (RESP) 00100010 group: 05 ON LVL: 255 RMPRT: 31 BUTTON: 5
0e4f Dining Room Light 1F.ED.6F RESP 10100010 group: 04 ON LVL: 0 RMPRT: 0 BUTTON: 4
0e47 Office Light 1F.EE.1B (CTRL) 01100010 group: 05 ON LVL: 3 RMPRT: 0 BUTTON: 5
0e3f Front Porch Keypad 2B.9B.8C (CTRL) 01100010 group: 05 ON LVL: 3 RMPRT: 0 BUTTON: 5
0e37 Back Hall Light 20.88.FC (CTRL) 01100010 group: 06 ON LVL: 3 RMPRT: 0 BUTTON: 6
0e2f Front Porch Keypad 2B.9B.8C (CTRL) 01100010 group: 08 ON LVL: 3 RMPRT: 0 BUTTON: 8
0e27 USB modem 3D.99.97 CTRL 11101010 group: 07 ON LVL: 3 RMPRT: 31 BUTTON: 7
0e1f USB modem 3D.99.97 CTRL 11100010 group: 06 ON LVL: 3 RMPRT: 31 BUTTON: 6
0e17 USB modem 3D.99.97 CTRL 11101010 group: 05 ON LVL: 3 RMPRT: 31 BUTTON: 5
0e0f USB modem 3D.99.97 CTRL 11100010 group: 04 ON LVL: 3 RMPRT: 31 BUTTON: 4
0e07 USB modem 3D.99.97 CTRL 11100010 group: 03 ON LVL: 3 RMPRT: 31 BUTTON: 3
0dff USB modem 3D.99.97 CTRL 11101010 group: 02 ON LVL: 3 RMPRT: 31 BUTTON: 2
0df7 USB modem 3D.99.97 CTRL 11101010 group: 01 ON LVL: 3 RMPRT: 31 BUTTON: 1
0def USB modem 3D.99.97 CTRL 11100010 group: 08 ON LVL: 3 RMPRT: 31 BUTTON: 8
0de7 00.00.00 00.00.00 (STOP) 00000000 group: 00 ON LVL: 0 RMPRT: 0 BUTTON: 0
Thank you for looking at this!!
Rudy
- Platform information:
- Hardware: Raspberry Pi 4
- OS: openhabian
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 3.0.1
