Hold On!
something has just happened, I have configured the item type as ‘Switch’ and it started working (it responds MUCH FASTER than any insteon app )
However, when I configure the type as Dimmer or RollerShutter it doesn’t work which takes out all the joy because I do want to be able to tell my automation system to open only half of the blind etc.
any idea how to make it work?
Type 'Switch:
2020-05-30 22:15:16.337 [DEBUG] [nternal.handler.InsteonDeviceHandler] - channel insteon:device:4DC52D:fastOnOff was triggered with the command OFF
2020-05-30 22:15:16.341 [DEBUG] [nsteon.internal.device.InsteonDevice] - processing command OFF features: 4
2020-05-30 22:15:16.345 [DEBUG] [steon.internal.device.CommandHandler] - FastOnOffCommandHandler: sent fast off to switch 4D.C5.2D
2020-05-30 22:15:16.345 [DEBUG] [nsteon.internal.device.InsteonDevice] - qe taken off direct: FastOnOff(1:1:2) OUT:Cmd:0x62|toAddress:4D.C5.2D|messageFlags:0x0F=DIRECT:3:3|command1:0x14|command2:0x00|
2020-05-30 22:15:16.347 [DEBUG] [ding.insteon.internal.InsteonBinding] - found binding config for channel insteon:device:4DC52D:fastOnOff
2020-05-30 22:15:16.347 [DEBUG] [nsteon.internal.device.InsteonDevice] - next request queue processed in 2000 msec, quiettime = 2000
2020-05-30 22:15:16.349 [DEBUG] [binding.insteon.internal.driver.Port] - writing (500): OUT:Cmd:0x62|toAddress:4D.C5.2D|messageFlags:0x0F=DIRECT:3:3|command1:0x14|command2:0x00|
2020-05-30 22:15:16.363 [DEBUG] [teon.internal.driver.hub.HubIOStream] - getting http://10.0.0.8:25105/3?02624dc52d0f1400=I=3
2020-05-30 22:15:17.245 [DEBUG] [ding.insteon.internal.InsteonBinding] - got msg: IN:Cmd:0x50|fromAddress:4D.C5.2D|toAddress:49.DE.C2|messageFlags:0x20=ACK_OF_DIRECT:0:0|command1:0x14|command2:0x00|
2020-05-30 22:15:17.248 [DEBUG] [nsteon.internal.device.InsteonDevice] - ----- applying message to feature: FastOnOff
2020-05-30 22:15:17.252 [DEBUG] [on.internal.device.MessageDispatcher] - 4D.C5.2D:FastOnOff DIRECT_ACK: q:QUERY_PENDING cmd: 80
2020-05-30 22:15:17.255 [DEBUG] [on.internal.device.MessageDispatcher] - changing key to 0x19 for msg IN:Cmd:0x50|fromAddress:4D.C5.2D|toAddress:49.DE.C2|messageFlags:0x20=ACK_OF_DIRECT:0:0|command1:0x14|command2:0x00|
2020-05-30 22:15:17.258 [DEBUG] [steon.internal.device.MessageHandler] - DefaultMsgHandler ignoring unimpl message with cmd1:0x14
2020-05-30 22:15:17.265 [DEBUG] [on.internal.device.MessageDispatcher] - defdisp: 4D.C5.2D:FastOnOff set status to: QUERY_ANSWERED
2020-05-30 22:15:17.269 [DEBUG] [nsteon.internal.device.DeviceFeature] - 4D.C5.2D:GenericLastTime publishing: 2020-05-30T22:15:17.268+0300
2020-05-30 22:15:18.345 [DEBUG] [.internal.device.RequestQueueManager] - device queue for 4D.C5.2D is empty!
Type ‘RollerShutter’:
2020-05-30 22:19:08.494 [ome.event.ItemCommandEvent] - Item ‘InsteonDevice4DC52D_FastOnOff’ received command DOWN
2020-05-30 22:19:08.499 [nt.ItemStatePredictedEvent] - InsteonDevice4DC52D_FastOnOff predicted to become DOWN
2020-05-30 22:19:08.507 [vent.ItemStateChangedEvent] - InsteonDevice4DC52D_FastOnOff changed from NULL to 100
