I’m trying openHAB 2.1 for the first time - running on a RPi3 from openhabianpi-raspbian-201706161358.
I have an Insteon 2413U PLM and am trying to install the binding from the UI (binding-insteonplm1 - 1.10.0). When I click on “Install” it gets stuck with the rotating wait icon. The services/insteonplm.cfg file seems to have been installed OK. If I shutdown and restart it doesn’t show the binding as being installed though.
The PLM shows up in as /dev/ttyUSB0
I’ve also edited the services/insteonplm.cfg file to reflect this.
Is there something I need to do to get this binding to install correctly? Are the any permissions I need to set?
Because this is an openHAB 1.x binding, you need to install by hand, don’t
use the GUI. I’m a long time openHAB 1.x user with insteon and installed a
test openHAB 2.x install and installed a working insteon binding in about 5
minutes. Just follow the directions on the WIKI page.
