I have a modbus device which gives me temperature and humidity readings in integer values where the last digit is always a fixed decimal place. So I need to divide all values by 10 to get a “real reading”.
Is this something that can be done in the items configuration? Or do I need to store them in a temp variable, and use a rule to calculate the /10 value into a new variable?
Thanks.
