Hello everybody, i think it’s time to post my rollershutter solution, i’m using nearly 10 Years
The motor self is controlled by follow UDF:
Hier is my UDF: RolladenMotor.pdf Rename pdf to zip!
Pulse on input I_UP
drives the rollo high, pulse on I_DO
drives the rollo down. The time rollo must be driven, are given by UDF parameters T_UP
and T_DO
respectively. As far output O_UP
is high, the rollo drives high. After the time T_UP
is past or O_UP
is high and new pulse is send to I_UP
, then O_UP
goes low. Output IS_UP
is set high, if pulse was send to I_UP
and time T_UP
is past. The same story is for I_DO
, O_DO
and IS_DO
. Additionally UDF calculates the rollo position between 0
and 100
percent, as need by openHAB. Some safety is given too: It’s not possible to set O_UP
and O_DO
high same time. It’s software lock only. It’s much better to lock additionally in hardware: we are talking here about 220V (life-threatening)! The circuit is simple: One relay controls the direction and another switches 220V on or off. The rest of Logo side is quite simple (cool spider, isn’t it?) :
Let’s take a look on openHAB side. First we need some things:
Thing pulse VB2_6 [ block="VB2.6", observe="NI23", pulse=500 ]
Thing pulse VB2_7 [ block="VB2.7", observe="NI24", pulse=500 ]
Thing memory VW116 [ block="VW116" ]
Then some items:
Switch RolloHi { channel="plclogo:pulse:LogoController:VB2_6:state" }
Switch RolloDo { channel="plclogo:pulse:LogoController:VB2_7:state" }
Contact RolloIsHi { channel="plclogo:pulse:LogoController:VB2_6:observed" }
Contact RolloIsDo { channel="plclogo:pulse:LogoController:VB2_7:observed" }
Switch RolloHiActive { channel="plclogo:digital:LogoController:Q:Q19" }
Switch RolloDoActive { channel="plclogo:digital:LogoController:Q:Q20" }
Number RolloPosition { channel="plclogo:memory:LogoController:VW116:value" }
Rollershutter Rollo "Rollo" <rollershutter>
And at least some rules:
val Procedures$Procedure4<Command, SwitchItem, SwitchItem, Command>
LogoRolloLogic = [ Command ReceivedCommand, SwitchItem Up, SwitchItem Down, Command Direction |
switch(ReceivedCommand) {
case UP: {
Up.sendCommand(OnOffType.ON)
case DOWN: {
Down.sendCommand(OnOffType.ON)
case STOP: {
if(Direction == UP) {
} else if (Direction == DOWN) {
} else if (Direction != STOP) {
logDebug("LogoRolloLogic", "Direction " + Direction + " is not supported.")
rule "RolloPosChanged"
Item RolloPosition changed
var Number value = RolloPosition.state as Number
Rollo.postUpdate(Math.max(Math.min(value.intValue, 100), 0))
rule "RolloDrive"
Item Rollo received command
var Command dir = STOP
if(RolloHiActive.state == OnOffType.ON) { dir = UP }
else if (RolloDoActive.state == OnOffType.ON) { dir = DOWN }
LogoRolloLogic.apply(receivedCommand, RolloHi, RolloDo, dir)
The theory of operation is quite simple: send pulses to properly blocks:-)
Kind regards,
Alexander
