Hi there
hm… i just connected with LogoSoftComfort again. I’m pretty sure that the TSAP settings are done there. (20.00 and 30.00)
anyway the Log is flooded with
2018-03-10 17:05:25.872 [WARN ] [nding.plclogo.internal.PLCLogoClient] - Reconnect during read from 192.168.0.21: TCP Sending error.
2018-03-10 17:05:37.968 [WARN ] [nding.plclogo.internal.PLCLogoClient] - Reconnect during read from 192.168.0.21: Data Receiving timeout.
2018-03-10 17:05:42.974 [WARN ] [nding.plclogo.internal.PLCLogoClient] - Reconnect during read from 192.168.0.21: TCP Sending error.
2018-03-10 17:05:47.980 [WARN ] [nding.plclogo.internal.PLCLogoClient] - Reconnect during read from 192.168.0.21: TCP Sending error.
2018-03-10 17:05:52.986 [WARN ] [nding.plclogo.internal.PLCLogoClient] - Reconnect during read from 192.168.0.21: TCP Sending error.
2018-03-10 17:05:57.989 [WARN ] [nding.plclogo.internal.PLCLogoClient] - Reconnect during read from 192.168.0.21: TCP Sending error.
2018-03-10 17:06:02.995 [WARN ] [nding.plclogo.internal.PLCLogoClient] - Reconnect during read from 192.168.0.21: TCP Sending error.
2018-03-10 17:06:23.353 [WARN ] [nding.plclogo.internal.PLCLogoClient] - Reconnect during read from 192.168.0.21: Data Receiving timeout.
2018-03-10 17:06:28.355 [WARN ] [nding.plclogo.internal.PLCLogoClient] - Reconnect during read from 192.168.0.21: TCP Sending error.
The interesting thing regarding ping: as soon as the Binding is started, Logo doesn’t respond to ping properely anymore. (~75% loss, or 3 out of 4 tries).
If not connected, its response time is 5ms avg (connected via power-line adapter).
One more thing. I was able to send one command (pulse output) one times. Light was going off. Could not be reproduced so far.
any idea?
PS:
I’m trying at a minimum config now - still without success:
*.things
Bridge plclogo:device:LogoRemise [ address="192.168.0.21", family="0BA8", localTSAP="0x3000", remoteTSAP="0x2000", refresh=100 ]
Thing pulse VB2_0 [ block="VB2.0", pulse=400 ] //Taste Aussenfluter aus
Thing pulse VB2_4 [ block="VB2.4", pulse=400 ] //Taste Aussenfluter ein
*.items
Switch VS_FluterRemise_ein {channel="plclogo:pulse:LogoRemise:VB2_4:state"}
Switch VS_FluterRemise_aus {channel="plclogo:pulse:LogoRemise:VB2_0:state"}
sending “ON” and “OFF” to these items using a rule
