I have an “old” Intel NUC and want to run openHAB 2 on it.
What is the easiest and best way to do it?
Is it Ubuntu Server and then use openhabian?
Thanks in advance!
Thanks in advance!
If you are not an experienced Linux/Unix user, I would install Ubuntu Desktop (you can always skip the X11 stuff later if you choose). After getting Ubuntu up and running, I would use Package setup (APT). Simply follow the instructions for APT based systems http://docs.openhab.org/installation/linux.html#installation
Follow the openHABian manual setup found here:
http://docs.openhab.org/installation/openhabian.html#manual-setup
Just my two cents: Install Ubuntu 16.04 LTS Server and then openhabian as luckymallari said.
Hey Emil
OpenHAB Ian on Ubuntu server is the smoothest way to archive your goals.
You only need a few Linux commands.
Good luck with your project!
Thanks everyone!
Used the Linux Server and openhabian
Hi @emil1,
I use Lubuntu ( Lubuntu is a lightweight Linux distribution based on Ubuntu ). Lubuntu is intended to be a low-system-requirement, low-RAM environment for netbooks, mobile devices, and older PCs.
See here for more infomation.
i’m not sure which NUC you have, but if you have a CPU with VT-d, i would recommend to install openhab in a VM, for example with proxmox or bare KVM.
Andvantage is, that you can create a additional test environment or other services, without influencing each other and you can do snapshots etc.
See:
https://www.proxmox.com/en/
https://wiki.debian.org/KVM
As this question was last addressed a while ago, would you all say this is still good advice.
I’ve got a ‘spare’ Pentium NUC and am looking to put OpenHab2 onto it.
I’m wondering if I’m better with Windows or some variant of Ubuntu? I am a novice when it comes to Unix but know Windows well.
Any advice greatly appreciated.
From my perspective the above still applies; I have a little NUC5i3 that runs Ubuntu 16.04 (server edition) in a VM very nicely and very reliably and I keep my Squeezebox server on it in a 2nd VM. OpenHabian helps with minimizing any Linux pain…
Thanks for the reply.
That’s an idea regarding a VM. Which VM hosting software do you use?
Just one more question, why do you use Ubuntu server rather than desktop?
Thanks.
I am running my NUC headless as I just parked in a remote corner and only use it in command line mode; I thought I would not need any of the user interfaces that come with the desktop version. AS far as I know whether or not graphical user interfaces will be installed is the major difference between server and desktop version.
I am using VirtualBox for my VMs. All works well, but the configuration of a VM is a steeper learning curve, as the command line interface requires a more reading and typing than a graphical interface.
Perhaps at this stage I’ll just go for basic Desktop Ubuntu hoSting directly on the ‘metal’.
I’ll also pop mine in a cupboard so will probably, have to remote onto when required.
Why not use the headless server edition and manage your vm through a web interface
That sounds awesome, did not know about this, thanks so much!!
That’s another interesting consideration.
I’m gueSsing that there are probably ‘pre-built’ VM instances with Ubuntu already installed in the VM image and then it’s just a matter of firing that VM image up and I’m ready to go?
One thought though. My NUC is only a dual core Pentium with 4GB RAM. I’m thinking that with that hardware, it might be somewhat challenged acting as a VM host?
Don‘t know, as I use my NUC for openHAB only. My VM‘s are running on a Gen8 Microserver running ESXi.
Just did a quick google search and posted the result.
Basically it‘s all about the ressources your VM‘s are allowed to use…
So, with something like your hosting software installed on the NUC, I could devote most (if not all) of the NUC’s resources over to a VM instance?
Yes, to give you a better feeling:
Server Hardware: Intel Xeon QuadCore with Hyperthreading, 16GB Ram
Running VMs:
Development : 2 Cores, 4GB Ram
Plex Media Server : 2 Cores, 4 GB Ram
Network Monitoring: 1 Core, 2 GB Ram
OwnCloud : 1 Core, 2 GB Ram
Windows 10 Pro : 2 Cores, 4 GB Ram (not running permanent)
Quite a substantial piece of hardware then.
So, all these VMs are running concurrently?
My other option is to use an old i5 laptop with 12GB RAM that I have.
This might be able to cope with more VMs I expect.
As regards the VM hosting software you’re using. Is that commercial or free?
