So Iāve gone and removed the item in the .items file and recreated a new item by first adding a thing, and then linking a thing an item by creating a new item. (Iāve confimed this method works by adding a new item switch2 which works perfectly)
the item now shows in list
openhab> smarthome:items list SHUTTER3655420261_*
SHUTTER3655420261_Shutter (Type=RollershutterItem, State=NULL, Label=Shutter, Category=null)
Here is the debug log capture for commands UP,STOP and DOWN:
UP
2017-02-12 09:35:03.887 [DEBUG] [rnal.connector.HomeduinoStreamReader] - Received message: 524620726563656976652035303736203136313620333238203636302031303530342030203020302030313233323332333332333233323332333232333332323332333233323332333233333232333332333233323332323332333233333232333332323332333233333232333233323333323233323332333334
2017-02-12 09:35:03.892 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (null): RF receive 5076 1616 328 660 10504 0 0 0 0123232332323232322332232323232323322332323232232323322332232323322323233223232334
2017-02-12 09:35:03.900 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:32466789 message: org.openhab.binding.homeduino.internal.messages.homeduino.Shutter3Message@1781eba
STOP
2017-02-12 09:35:12.111 [DEBUG] [rnal.connector.HomeduinoStreamReader] - Received message: 524620726563656976652035303736203136313620333332203635362031303530382030203020302030313233323332333332333233323332333232333332323332333233323332333233333232333332333233323332323332333233333232333332323332333233333232333332323333323233333232333334
2017-02-12 09:35:12.114 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (null): RF receive 5076 1616 332 656 10508 0 0 0 0123232332323232322332232323232323322332323232232323322332232323322332233223322334
2017-02-12 09:35:12.121 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:32466789 message: org.openhab.binding.homeduino.internal.messages.homeduino.Shutter3Message@447cbf
DOWN
2017-02-12 09:35:19.353 [DEBUG] [rnal.connector.HomeduinoStreamReader] - Received message: 524620726563656976652035303736203136313620333332203635362031303532342030203020302030313233323332333332333233323332333232333332323332333233323332333233333232333332333233323332323332333233333232333332323332333233333232333233333233323233323333323334
2017-02-12 09:35:19.356 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (null): RF receive 5076 1616 332 656 10524 0 0 0 0123232332323232322332232323232323322332323232232323322332232323322323323223233234
2017-02-12 09:35:19.363 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:32466789 message: org.openhab.binding.homeduino.internal.messages.homeduino.Shutter3Message@169a973
These captures differ slightly from my previous ones as these are generated by my 433 shutter control python script (shutters respond to these commands). Iām posting these as they might help debugging, since the original remote control sends out two codes for up and down (UP pressed once gives commands from 23:35:16.277 - 23:35:16.527 and DOWN pressed once gives 23:35:25.822- 23:35:26.071)
The item state however remains unchanged
EDIT:
I can also confirm that the manual method iāve used to add items in .items file also works - you can use this way to add new items (Coming form 1.x i feel this manual approach gives me much more control over my items):
Switch TestSwitch2 {channel="homeduino:switch2:32466789:3_8:command"}
where homeduino:switch2:32466789:3_8:command
is command channel you select in the things view in paperUI.
This is in mine;
SWITCH2-3.8
Homeduino Switch2 Actuator
A Switch2 device.
Status: ONLINE
Channels
Command
Command channel
Contact
homeduino:switch2:32466789:3_8:contact
Contact channel
this is the event log when i press the remotes;
2017-02-12 10:00:44.292 [ItemStateChangedEvent ] - SWITCH238_Command changed from OFF to ON
2017-02-12 10:00:44.295 [ItemStateChangedEvent ] - TestSwitch2 changed from NULL to ON
2017-02-12 10:00:53.878 [ItemStateChangedEvent ] - TestSwitch2 changed from ON to OFF
2017-02-12 10:00:53.885 [ItemStateChangedEvent ] - SWITCH238_Command changed from ON to OFF
2017-02-12 10:01:04.159 [ItemStateChangedEvent ] - TestSwitch2 changed from OFF to ON
2017-02-12 10:01:04.166 [ItemStateChangedEvent ] - SWITCH238_Command changed from OFF to ON
SWITCH238_Command
was created by linking via PaperUI and TestSwitch2
by adding the above in the .items file.
