The devil is in the details here, in the sequence of 0,1,2 & 3ās the numbers refer to the numbers (pulse-lengths) in front so if you reshuffle the numbers in front the signal looks different but is the same, with the numbers in sorted order your working output signal is: 32010101101010101001100101010101011001101010100101011001100101011001011010**101001**04
So the difference is in the last part, can you check whether sending of the following does work?
Great, the existing README was just the one of the rfxcom so there should be some trimming on the existing texts as well. We could also add some reference (text and/or links) about supported protocols and about the homeduino itself.
Iāve installed the new Snapshot from yesterday eveningā¦ the weather1 sensor was directly in the inboxā¦thing definition, items definition ā¦ no problemsā¦it seems to work perfectly.
Only the log info shows me some information I can not point to.
Here is the log:
18:53:21.172 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'homeduino:weather1:4ea8812e:120_1' changed from UNINITIALIZED to INITIALIZING
18:53:21.180 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Initializing thing homeduino:weather1:4ea8812e:120_1
18:53:21.183 [DEBUG] [ding.homeduino.handler.RFXComHandler] - initializeBridge ONLINE for thing homeduino:weather1:4ea8812e:120_1
18:53:21.190 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'homeduino:weather1:4ea8812e:120_1' changed from INITIALIZING to ONLINE
18:53:37.295 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 504 1940 3888 9192 0 0 0 0 01020102010202020201010102010101010101020101010101020201010102020101020103
18:53:37.304 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@9c173
18:53:37.323 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:53:37.789 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 516 1928 3876 9180 0 0 0 0 01020102010202020201010102010101010101020101010101020201010102020101020103
18:53:37.796 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@851436
18:53:37.802 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:53:40.840 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'WEATHER1Aussen_Temperature' has been added.
18:53:41.466 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received channel: homeduino:weather1:4ea8812e:120_1:temperature, command: REFRESH
18:53:41.470 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'WEATHER1Aussen_Temperature-homeduino:weather1:4ea8812e:120_1:temperature' has been added.
18:53:46.839 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'WEATHER1Aussen_Humidity' has been added.
18:53:47.402 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received channel: homeduino:weather1:4ea8812e:120_1:humidity, command: REFRESH
18:53:47.407 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'WEATHER1Aussen_Humidity-homeduino:weather1:4ea8812e:120_1:humidity' has been added.
18:53:53.287 [INFO ] [smarthome.event.ItemAddedEvent ] - Item 'WEATHER1Aussen_LowBattery' has been added.
18:53:53.854 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received channel: homeduino:weather1:4ea8812e:120_1:lowBattery, command: REFRESH
18:53:53.861 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'WEATHER1Aussen_LowBattery-homeduino:weather1:4ea8812e:120_1:lowBattery' has been added.
18:54:01.783 [INFO ] [marthome.event.ItemStateChangedEvent] - Systeminfo_openhabian_Network_DataSent changed from 769 to 771
18:54:09.466 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 508 1936 3884 9188 0 0 0 0 01020102010202020201010102020101010101020101010101020201010102020101020103
18:54:09.480 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@31510c
18:54:09.496 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:54:09.500 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Temperature changed from NULL to 26.199999999999999289457264239899814128875732421875
18:54:09.506 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Humidity changed from NULL to 50
18:54:09.963 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 516 1928 3876 9172 0 0 0 0 01020102010202020201010102020101010101020101010101020201010102020101020103
18:54:09.979 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@1e9729c
18:54:09.994 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:54:12.247 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Checking Homeduino transceiver connection, thing status = ONLINE
18:54:14.730 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 512 1928 3880 9196 0 0 0 0 01020102010202020201010102020101010101020101010101020201010102020101020103
18:54:14.736 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@10c7115
18:54:14.749 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:54:15.231 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 512 1928 3880 9188 0 0 0 0 01020102010202020201010102020101010101020101010101020201010102020101020103
18:54:15.245 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@1f0f566
18:54:15.269 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:54:16.179 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 512 1928 3880 9180 0 0 0 0 01020102010202020201010102020101010101020101010101020201010102020101020103
18:54:16.191 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@18562a5
18:54:16.215 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:54:16.682 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 512 1928 3876 9184 0 0 0 0 01020102010202020201010102020101010101020101010101020201010102020101020103
18:54:16.694 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@191402c
18:54:16.713 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:54:51.791 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 508 1936 3880 9192 0 0 0 0 01020102010202020201010102010101010101020101010102010101010102020101020203
18:54:51.799 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@1198a71
18:54:51.811 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:54:51.821 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Temperature changed from 26.199999999999999289457264239899814128875732421875 to 26.39999999999999857891452847979962825775146484375
18:54:51.836 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Humidity changed from 50 to 51
18:54:52.281 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 512 1932 3880 9160 0 0 0 0 01020102010202020201010102010101010101020101010102010101010102020101020203
18:54:52.287 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@18e65a
18:54:52.295 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:55:01.798 [INFO ] [marthome.event.ItemStateChangedEvent] - Systeminfo_openhabian_Network_DataReceived changed from 1237 to 1238
18:55:12.247 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Checking Homeduino transceiver connection, thing status = ONLINE
18:55:13.605 [INFO ] [marthome.event.ItemStateChangedEvent] - Sonos_Schlafzimmer_Control changed from PLAY to PAUSE
18:55:21.739 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Thing homeduino:weather1:4ea8812e:120_1 disposed.
18:55:21.742 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Initializing thing homeduino:weather1:4ea8812e:120_1
18:55:21.743 [DEBUG] [ding.homeduino.handler.RFXComHandler] - initializeBridge ONLINE for thing homeduino:weather1:4ea8812e:120_1
18:55:21.758 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'homeduino:weather1:4ea8812e:120_1' has been updated.
18:55:26.795 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 508 1936 3884 9176 0 0 0 0 01020102010202020201010102010101010101020101010102010102010102020102010203
18:55:26.800 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@1c84269
18:55:26.810 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:55:26.819 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Temperature changed from 26.39999999999999857891452847979962825775146484375 to 26.5
18:55:26.829 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Humidity changed from 51 to 53
18:55:27.295 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 512 1932 3876 9180 0 0 0 0 01020102010202020201010102010101010101020101010102010102010102020102010203
18:55:27.300 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@57e91c
18:55:27.309 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:55:57.959 [INFO ] [marthome.event.ItemStateChangedEvent] - AstroSunData_Position_Elevation changed from -10.91 to -11.70
18:56:01.787 [INFO ] [marthome.event.ItemStateChangedEvent] - Systeminfo_openhabian_Network_DataSent changed from 771 to 772
18:56:01.794 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 508 1936 3888 9176 0 0 0 0 01020102010202020201010102010101010101020101010102010102010102020101020203
18:56:01.802 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@14cbbe5
18:56:01.813 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:56:01.821 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Humidity changed from 53 to 51
18:56:02.296 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 512 1932 3880 9180 0 0 0 0 01020102010202020201010102010101010101020101010102010102010102020101020203
18:56:02.303 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@11b720
18:56:02.313 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:56:12.247 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Checking Homeduino transceiver connection, thing status = ONLINE
18:56:36.796 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 508 1936 3888 9180 0 0 0 0 01020102010202020201010102010101010101020101010101020202010102020101020103
18:56:36.802 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@1537801
18:56:36.811 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:56:36.817 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Temperature changed from 26.5 to 26.300000000000000710542735760100185871124267578125
18:56:36.824 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Humidity changed from 51 to 50
18:56:37.295 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 512 1928 3880 9180 0 0 0 0 01020102010202020201010102010101010101020101010101020202010102020101020103
18:56:37.300 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@27637e
18:56:37.311 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:57:11.786 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 504 1936 3888 9188 0 0 0 0 01020102010202020201010102010101010101020101010101020102010102020101010103
18:57:11.794 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@54630c
18:57:11.813 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Temperature changed from 26.300000000000000710542735760100185871124267578125 to 26.10000000000000142108547152020037174224853515625
18:57:11.814 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:57:11.823 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Humidity changed from 50 to 48
18:57:12.247 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Checking Homeduino transceiver connection, thing status = ONLINE
18:57:12.266 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 512 1928 3880 9184 0 0 0 0 01020102010202020201010102010101010101020101010101020102010102020101010103
18:57:12.270 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@1836091
18:57:12.283 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:57:46.786 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 500 1940 3888 9196 0 0 0 0 01020102010202020201010102010101010101020101010101010201010102020101010103
18:57:46.791 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@1e09010
18:57:46.800 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:57:46.809 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Temperature changed from 26.10000000000000142108547152020037174224853515625 to 25.800000000000000710542735760100185871124267578125
18:57:47.250 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 512 1932 3880 9180 0 0 0 0 01020102010202020201010102010101010101020101010101010201010102020101010103
18:57:47.256 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@e73201
18:57:47.270 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:58:00.023 [INFO ] [marthome.event.ChannelTriggeredEvent] - astro:sun:8bcd80a3:nauticDusk#event triggered END
18:58:00.031 [INFO ] [marthome.event.ChannelTriggeredEvent] - astro:sun:8bcd80a3:astroDusk#event triggered START
18:58:01.785 [INFO ] [marthome.event.ItemStateChangedEvent] - Systeminfo_openhabian_Network_DataSent changed from 772 to 773
18:58:01.795 [INFO ] [marthome.event.ItemStateChangedEvent] - Systeminfo_openhabian_Network_DataReceived changed from 1238 to 1239
18:58:12.247 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Checking Homeduino transceiver connection, thing status = ONLINE
18:58:21.828 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 508 1936 3884 9172 0 0 0 0 01020102010202020201010102010101010101010202020202020202010102010202020203
18:58:21.835 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@1e87792
18:58:21.847 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:58:21.851 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Temperature changed from 25.800000000000000710542735760100185871124267578125 to 25.5
18:58:21.858 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Humidity changed from 48 to 47
18:58:43.968 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
18:58:44.316 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
18:58:56.818 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 512 1932 3884 9168 0 0 0 0 01020102010202020201010102010101010101010202020202020102010102010202020203
18:58:56.824 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@1eb1a16
18:58:56.834 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
18:58:56.841 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Temperature changed from 25.5 to 25.300000000000000710542735760100185871124267578125
18:59:01.803 [INFO ] [marthome.event.ItemStateChangedEvent] - Systeminfo_openhabian_Network_DataReceived changed from 1239 to 1240
18:59:12.247 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Checking Homeduino transceiver connection, thing status = ONLINE
18:59:31.817 [DEBUG] [duino.handler.HomeduinoBridgeHandler] - Message received (HOMEDUINO_RF_EVENT): RF receive 508 1932 3884 9176 0 0 0 0 01020102010202020201010102010101010101010202020202010202010102010202020203
18:59:31.823 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Received message from bridge: homeduino:homeduino:4ea8812e message: org.openhab.binding.homeduino.internal.messages.homeduino.Weather1Message@e0786b
18:59:31.840 [INFO ] [marthome.event.ItemStateChangedEvent] - WEATHER1Aussen_Temperature changed from 25.300000000000000710542735760100185871124267578125 to 25.10000000000000142108547152020037174224853515625
18:59:31.843 [ERROR] [ding.homeduino.handler.RFXComHandler] - Error occured during message receiving: org.eclipse.smarthome.core.library.types.OnOffType cannot be cast to org.eclipse.smarthome.core.library.types.DecimalType
It seems that there is a problem with the received data, because the error occurs after every delivery of the sensor.
Thank you Martin for your effort. If you need more information, please tell me.
Hi Martin,
can you please give me a hint. With the newest snapshot and your newest .jar i get this error:
20:36:23.391 [INFO ] [smarthome.event.InboxRemovedEvent ] - Discovery Result with UID 'homeduino:switch2:7f156175:11_16' has been removed.
20:36:23.396 [INFO ] [smarthome.event.ThingAddedEvent ] - Thing 'homeduino:switch2:7f156175:11_16' has been added.
20:36:23.412 [DEBUG] [ding.homeduino.handler.RFXComHandler] - Initializing thing homeduino:switch2:7f156175:11_16
20:36:23.412 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'homeduino:switch2:7f156175:11_16' changed from UNINITIALIZED to INITIALIZING
20:36:23.414 [DEBUG] [ding.homeduino.handler.RFXComHandler] - initializeBridge ONLINE for thing homeduino:switch2:7f156175:11_16
20:36:23.421 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'homeduino:switch2:7f156175:11_16' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): RFXCOM device missing deviceId or subType
I deleted the things, used my remotecontrol, 3 things where found and when i added the things - this is the result.
What could it be?
Thanks - Karl Heinz
openhab> bundle:list
START LEVEL 100 , List Threshold: 50
ID | State | Lvl | Version | Name
9 | Active | 80 | 2.1.0.201702121334 | Homeduino Binding
