JensK
(Jens Kluge)
#1
Have updated my YAHM to new firmware 2.31.25
Now have problems to conect with ccu.
Follow log
2018-01-27 10:04:21.478 [INFO ] [ternal.communicator.client.RpcClient] - Interface 'CUXD' on gateway 'ccu' not available, disabling support
2018-01-27 10:04:21.530 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=HMLGW2,firmware=2.31.25,address=KEQ1066857,wired=true,hmip=true,cuxd=false,group=true]
Have you installed the Add-on CUXD ? If not, then all fine
JensK
(Jens Kluge)
#3
hm… actually not sure what this is.
What i have installed at homematic side is Funk-Modul (HM-MOD-RPI-PCB) nothing else.
CUXD is an Add-on for the CCU …
https://www.homematic-inside.de/software/cuxdaemon
Openhab deactivate the Support, if the Add-on is not installed … so that no Error … it’s a Feature
You can ignore this Log Entry
