I’m currently testing my openHAB for Garmin app, which regularly polls the sitemap API via myopenHAB.org
. Both I and other users have noticed that, occasionally - and somewhat regularly - the API returns an HTTP 200 (OK) status, but with no content in the response body.
I’ve reproduced this behavior outside of the Garmin app as well, simply by repeatedly requesting the same URL in Firefox:
https://home.myopenhab.org/rest/sitemaps/garmin_demo
(garmin_demo
is the sitemap name.)
Below are the HTTP request and response headers captured during one of these empty responses (authorization info removed).
Has anyone experienced similar behavior or have insight into what’s causing it? I initially suspected rate limiting, but I’d expect the server to respond with a 429 Too Many Requests
or 503 Service Unavailable
in that case - not a 200 OK
Any help or suggestions would be appreciated!
GET /rest/sitemaps/garmin_demo HTTP/1.1
Host: home.myopenhab.org
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:138.0) Gecko/20100101 Firefox/138.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-GB,en;q=0.5
Accept-Encoding: gzip, deflate, br, zstd
Authorization: Basic REMOVED
Connection: keep-alive
Cookie: __utma=211485577.443714860.1715675546.1732260971.1746011753.6; __utmz=211485577.1715675546.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); _ga=GA1.2.443714860.1715675546; _ga_BGSSTP9020=GS1.2.1746011173.1.1.1746011173.0.0.0; X-OPENHAB-AUTH-HEADER=true; CloudServer=10.11.0.31%3A3000
Upgrade-Insecure-Requests: 1
Sec-Fetch-Dest: document
Sec-Fetch-Mode: navigate
Sec-Fetch-Site: none
Sec-Fetch-User: ?1
Priority: u=0, i
HTTP/1.1 200 OK
Server: nginx/1.18.0 (Ubuntu)
Date: Thu, 01 May 2025 18:24:10 GMT
Content-Length: 0
X-Powered-By: Express
Set-Cookie: CloudServer=10.11.0.31%3A3000; Max-Age=900; Path=/; Expires=Thu, 01 May 2025 18:39:10 GMT; HttpOnly
Set-Cookie: X-OPENHAB-AUTH-HEADER=true; Path=/
