I have an OH3.2.0.M1 installation on Windows. I am trying to use the intersection character to join transformations (∩). I checked the org.openhab.core.thing.Thing.json file and the encoding is UTF8. If I type this character into the transformation then it gets saved as “?” in the file and on the next restart the transformations are not working (as the intersection character gets changed to a “?”).
Any idea what should I change in order to get this character stored properly in the db? I tried to manually overwrite in the file but in that case on the next start it is even more messed up.
Please be aware that there are two different symbols which look very similar : ∩ and ⋂ (really annoying)
tbh I always copy&paste the correct symbol directly from mqtt channel incomming transformation help text: ∩
