Good Morning Jürgen,
im sure we will get this running. After installing openhab again ive setup the intertechno.cfg, the items and the sitemap, cleared the logfile and started openhab again. This is what logfile saved:
2017-11-02 10:54:58.701 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items’2017-11-02 10:55:08.474 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap’2017-11-02 10:55:11.633 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.2.111:80802017-11-02 10:55:11.640 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.2.111:84432017-11-02 10:55:12.769 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app2017-11-02 10:55:14.153 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui2017-11-02 10:55:14.835 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel2017-11-02 10:55:15.247 [WARN ] [io.transport.cul.CULLifecycleManager] - CUL config is NULL, doing nothing2017-11-02 10:55:15.263 [INFO ] [ternal.serial.CULSerialConfigFactory] - Update config, baudrate = 384002017-11-02 10:55:15.280 [INFO ] [ternal.serial.CULSerialConfigFactory] - Update config, parity = NONE (0)
seems to be okay on the first look?
Actually i am connected via vpn so i cant say if my switches are changing their status after a click on the button which is shown on the sitemap
culintertechno.cfg:
#Devicename to use (mandatory)
example /dev/ttyACM0
device= serial:/dev/ttyUSB0#How often should the command be repeated? (optional)
#See culfw reference for details
#repetitions=6#How long should one pulse be? (optional)
#wavelength=420culintertechno:baudrate=38400
culintertechno:parity=NONE
culintertechno:device=serial:/dev/ttyUSB0
repititions=6
wavelength=420
just to be sure? dmesg returns this so i guess ttyUSB0 is correct for my CUL:
5.705094] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
i also tried this: New 433 Mhz CUL and Intertechno Binding - #61 by Marko_Kraft - here is the problem that i am not able to read the CUL Firmware with minicom ![]()
