I have upgraded vom 3.1 to 3.4m3 and I lost a roborock, I lost echo-Control, the doorbird is not working… and maybe more… so to make finding easier, why not have a rule that I can trigger in a room that tests everything in this room and I just watch things move, turn on , react?
Sounds simple, but it took me 4 years to realize that this is missing in my setup
so here is my first simple rule for my living room.
That is build with a script, an item and a page-thingy-column-cell
Script:
events.postUpdate("Wohnzimmer_Tests", "starte tests")
var Tests = [];
//Tests.push('Echo');
//Tests.push('Rollladen');
Tests.push('Sichtschutz');
Tests.forEach(function (test_to_run) {
if(test_to_run == 'Echo'){
events.postUpdate("Wohnzimmer_Tests", "teste Amazon Echo")
var echo_test_nachricht = '<speak><audio src="soundbank://soundlibrary/home/amzn_sfx_doorbell_chime_01"/>' +
'<say-as interpret-as="interjection">Test</say-as>' +
'<break time="100ms"/>'+
'<say-as interpret-as="interjection">1 2 3</say-as>'+
'</speak>';
events.sendCommand("Wohnzimmer_Echo_Sprich",echo_test_nachricht)
if(test_to_run == 'Rollladen'){
var Rollladen = [];
Rollladen.push("WohnzimmerFensterHintenRollladen_Position");
Rollladen.push("WohnzimmerFensterMitteRollladen_Position");
Rollladen.push("WohnzimmerFensterVorneRollladen_Position");
Rollladen.forEach(function (value) {
events.postUpdate("Wohnzimmer_Tests", "teste Rollladen" + value )
var position_before_testing = itemRegistry.getItem( value ).getState()
events.sendCommand(value,"0")
java.lang.Thread.sleep(3000)
events.sendCommand(value,"100")
events.sendCommand(value,position_before_testing)
if(test_to_run == 'Sichtschutz'){
var Sichtschutz = [];
Sichtschutz.push("WohnzimmerFensterHintenSichtschutz_Position");
Sichtschutz.push("WohnzimmerFensterVorneSichtschutz_Position");
Sichtschutz.forEach(function (value) {
events.postUpdate("Wohnzimmer_Tests", "teste Sichtschutz" + value)
events.postUpdate("Wohnzimmer_Tests", "Test beendet")
events.postUpdate("Wohnzimmer_Tests", "") //status is cleared, test is not running anymore.
item:
component: oh-list-card
simpleList: false
title: Systemtest
slots:
default:
- component: oh-label-item
item: Wohnzimmer_Tests
title: Wohnzimmer
icon: f7:arrow_right_circle
action: rule
actionRule: Test_Wohnzimmer
actionFeedback: Starte mit den Tests
iconUseState: false
