usambara
(Ulrich)
August 26, 2017, 11:24am
#1
I received the first time these interesting warnings:
2017-08-23 11:32:35.623 [WARN ] [.commandclass.ZWaveColorCommandClass] - NODE 4: Invalid color 10
2017-08-23 11:32:35.665 [WARN ] [.commandclass.ZWaveColorCommandClass] - NODE 4: Invalid color 14
2017-08-23 11:32:35.709 [WARN ] [.commandclass.ZWaveColorCommandClass] - NODE 4: Invalid color 15
The device is a Fibaro FGRM222 Roller Shutter. I can’t see any useful relation between the message and the device…
wtf?
Can you post your *.items file ?
chris
(Chris Jackson)
August 28, 2017, 10:03am
#3
Please can you post a debug log showing the received messages that are causing this.
The issue here won’t be related to the items definitions - this means that a colour command has been received from the device and the binding doesn’t know the colour since (from memory) ZWave only defines colours from 1 to 8 or 9.
usambara
(Ulrich)
August 28, 2017, 4:06pm
#4
Hi BrutalBirdie,
here you have the items. Why do you think there could be a relation?
Switch cWoZi_RolladenWest "Rolladen Wohnzimmer West Auf/Zu" <rollershutter> (gWohnzimmer,gRolladen) { channel="zwave:device:gehirn:node4:switch_binary" }
Rollershutter dWoZi_RolladenWest "Rolladen Wohnzimmer West %" <rollershutter> (gWohnzimmer,gRolladen) { channel="zwave:device:gehirn:node4:blinds_control", config_invert_percent="true", config_invert_control="false" }
Number nWoZi_RolladenWestStrom "Rolladen Wohnzimmer West Strom [%.2f kWh]" <line> (gStromverbrauch) { channel="zwave:device:gehirn:node4:meter_kwh" }
usambara
(Ulrich)
August 28, 2017, 4:09pm
#5
Hi Chris,
I’ve activated the debug log now. Let’s see when it happens again, for now it has been only once.
Thanks for assistance
Ulrich
usambara
(Ulrich)
September 9, 2017, 2:03pm
#6
Until now the message didn’t come up again.
What ever it was…
