Ohh sorry, it was in the code, all the valid parameters (in qoutes) :
RAW_DATA(“RawData”, StringItem.class),
SHUTTER(“Shutter”, RollershutterItem.class),
COMMAND(“Command”, SwitchItem.class),
MOOD(“Mood”, NumberItem.class),
SIGNAL_LEVEL(“SignalLevel”, NumberItem.class),
DIMMING_LEVEL(“DimmingLevel”, DimmerItem.class),
TEMPERATURE(“Temperature”, NumberItem.class),
HUMIDITY(“Humidity”, NumberItem.class),
HUMIDITY_STATUS(“HumidityStatus”, StringItem.class),
CHIME_SOUND(“ChimeSound”, NumberItem.class),
BATTERY_LEVEL(“BatteryLevel”, NumberItem.class),
PRESSURE(“Pressure”, NumberItem.class),
FORECAST(“Forecast”, StringItem.class),
RAIN_RATE(“RainRate”, NumberItem.class),
RAIN_TOTAL(“RainTotal”, NumberItem.class),
WIND_DIRECTION(“WindDirection”, NumberItem.class),
WIND_SPEED(“WindSpeed”, NumberItem.class),
WIND_AVSPEED(“WindAvSpeed”, NumberItem.class),
UV(“UV”, NumberItem.class),
GUST(“Gust”, NumberItem.class),
CHILL_FACTOR(“ChillFactor”, NumberItem.class),
INSTANT_POWER(“InstantPower”, NumberItem.class),
TOTAL_USAGE(“TotalUsage”, NumberItem.class),
INSTANT_AMPS(“InstantAmps”, NumberItem.class),
TOTAL_AMP_HOURS(“TotalAmpHours”, NumberItem.class),
INSTANT_ENERGY(“InstantEnergy”, NumberItem.class),
CHANNEL1_AMPS(“Channel1Amps”, NumberItem.class),
CHANNEL2_AMPS(“Channel2Amps”, NumberItem.class),
CHANNEL3_AMPS(“Channel3Amps”, NumberItem.class),
POWER_FACTOR(“PowerFactor”, NumberItem.class),
STATUS(“Status”, StringItem.class),
WEIGHT(“Weight”, NumberItem.class),
MOTION(“Motion”, SwitchItem.class),
CONTACT(“Contact”, ContactItem.class),
CONTACT_1(“Contact1”, ContactItem.class),
CONTACT_2(“Contact2”, ContactItem.class),
CONTACT_3(“Contact3”, ContactItem.class),
VOLTAGE(“Voltage”, NumberItem.class),
SET_POINT(“SetPoint”, NumberItem.class),
DATE_TIME(“DateTime”, DateTimeItem.class),
FREQUENCY(“Frequency”, NumberItem.class);
