Hello all,
I have some issues with the map transformation in openHAB 3. My shelly 2.5 shutter switches provide me with a channel representing the shutter position as a dimmer. So, they show me e.g. 100 % for fully opened. But, I’d need them to show 0 % when fully opened. As I didn’t find any configuration to change this behavior I would like to perform a map transformation. Therefore, I put the mapping file “invertDimmer.map” in the respective transform folder with the following content:
0 = 100
1 = 99
2 = 98
99 = 1
100 = 0
The Map Transformation Binding is doing its job as I tested it with a string channel successfully.
The dimmer value is given in percent so that I also tried to play a bit with the unit formats like testing the argument index “%1$d” or something like that. All without success. Could somebody help me out here? It shouldn’t be too complicated but something I seem to overlook?
The error message in the log file says the following:
2023-02-22 16:15:08.664 [WARN ] [al.profiles.MapTransformationProfile] - Could not transform state '52 %' with function 'invertDimmer.map' and format '%1$d'
In the follwong you see my entries in the item/channel setup:
Thanks in advance!
