hello,
is it possible to invert the percentage of an item linked to a zwave channel? Dimmer Serranda_Cucina_Alexa_Proxy {channel="zwave:device:60d32216:node5:blinds_control"}
The percentage of the blind is corrected configured, but if I try to control it with alexa, I should invert the behaviour of the RolleShutter (connected to alexa through the Dimmer item), so I mean if is possible to change the percentage only for this item?
As @Bruce_Osborne mentioned a proxy item and rule will work. He also gave a link that I encourage everyone to read thru. The more effort and info you provide will result in better and fast responses.
Most that are needing help with a rule can find a similar solution by searching the forum. I did a quick search and found a rule that may help with your situation. Note this example does not use a proxy item but it should be enough to get you started. Play around some and if you hit a snag post what you have, the error logs and we can try to help.
rule "Buero_Colortemp_Alexa Commands"
Item Buero_Colortemp_Alexa received command
Buero_Colortemp_Test.sendCommand(100 - receivedCommand as PercentType)
rule "Buero_Colortemp_Test Changes"
Item Buero_Colortemp_Test changed
Buero_Colortemp_Alexa.postUpdate(100 - Buero_Colortemp_Test.state as PercentType)
Thank you H102!
Running RPi 3b+, oH 2.4 Stable.
I also was having an issue and discovered this solution for my item which is an mqtt device. I would think this will work with zigbee and zwave.
