I have a small problem with the vision zg8101 modules .
They are installed and configured correctly but when I look in the documentation when the position is vertical , the module should return the status " CLOSED " .
If I look in the events.log file, it is the opposite
Someone has an explanation?
Thank you
Openhab 1.7 out raspberry
Stick Aeon Zwave
File items :
Contact Porte_Garage_Gauche " left the garage door [MAP ( garage.map ) :% d ] " < garagedoor > ( UF_GarageG ) { Zwave = " 8: command = sensor_binary , respond_to_basic = true "}
