Since a couple of weeks, I see a lot of warnings and error like below.
I already saw some posts which were pointing to the apps, but I don’t use them. I only use the url (https://home.myopenhab.org/basicui/app) and have a shortcut on my homescreen
It’s not that the logs appear when I open this page, can’t realy pinpoint when this happens
Well, an old issue, but not solved yet. Although things work well despite of that warnings it is very annoying having them in the logfile. Is there at least a possibility to switch off the warnings, i.e. to set the log level to ERROR? I don’t know which name I have to use in the org.ops4j.pax.logging.cfg file, similar to the standard entry like for example
log4j2.logger.openhab.name = org.openhab
log4j2.logger.openhab.level = INFO
I run OH 2.4.0 on my Synology DS216+. Unfortunately, there is still no M2.5 snapshot available at the moment. At least, I couldn’t find any. The hint with the :443 port I tried already, but no success. Seems I have to wait until 2.5 is available for synology.
I hadn’t seen this post, but fwiw I just posted a similar issue using iOS App to connect to the openhabcloud. My 2.5M5 installation is a Docker, not Synology. I was finally able to remotely connect, but just get these warnings in the log.
My story behind is, that I had a very slow and unstable OH, getting slower and slower. The reason was my influx installation. Although I had only a few data to persist influx used more then 80% of CPU and RAM!!! I will post this in detail in another thread. I uninstalled influx and now everything works fine. But the issue with iOS changed a little bit since that time. Jetty request failure doesn’t occur anymore, therefore each time I connect to OH cloud I get the following:
019-12-13 05:39:01.846 [ERROR] [org.openhab.io.openhabcloud.internal.CloudClient ] - Socket.IO error: {}
io.socket.engineio.client.EngineIOException: websocket error
at io.socket.engineio.client.Transport.onError(Transport.java:71) [232:org.openhab.io.openhabcloud:2.4.0]
at io.socket.engineio.client.transports.WebSocket.access$500(WebSocket.java:28) [232:org.openhab.io.openhabcloud:2.4.0]
at io.socket.engineio.client.transports.WebSocket$2$5.run(WebSocket.java:150) [232:org.openhab.io.openhabcloud:2.4.0]
at io.socket.thread.EventThread$2.run(EventThread.java:80) [232:org.openhab.io.openhabcloud:2.4.0]
Caused by: java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:210) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:?]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:?]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:940) ~[?:?]
at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) ~[?:?]
at okio.Okio$2.read(Okio.java:138) ~[?:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:238) ~[?:?]
at okio.RealBufferedSource.request(RealBufferedSource.java:66) ~[?:?]
at okio.RealBufferedSource.require(RealBufferedSource.java:59) ~[?:?]
at okio.RealBufferedSource.readByte(RealBufferedSource.java:72) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.readHeader(WebSocketReader.java:115) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.processNextFrame(WebSocketReader.java:104) ~[?:?]
at okhttp3.internal.ws.RealWebSocket.readMessage(RealWebSocket.java:97) ~[?:?]
at okhttp3.ws.WebSocketCall.createWebSocket(WebSocketCall.java:152) ~[?:?]
at okhttp3.ws.WebSocketCall.access$000(WebSocketCall.java:41) ~[?:?]
at okhttp3.ws.WebSocketCall$1.onResponse(WebSocketCall.java:97) ~[?:?]
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:126) ~[?:?]
at okhttp3.internal.NamedRunnable.run(NamedRunnable.java:32) ~[?:?]
... 3 more
2019-12-13 05:39:01.898 [INFO ] [org.openhab.io.openhabcloud.internal.CloudClient ] - Disconnected from the openHAB Cloud service (UUID = *******, base URL = http://localhost:8080)
2019-12-13 05:39:05.873 [INFO ] [org.openhab.io.openhabcloud.internal.CloudClient ] - Connected to the openHAB Cloud service (UUID = *****, base URL = http://localhost:8080)
