Hello community,
I am using the iOS app which is very fast - what I like - but has one major issue:
When having defined long labels in the sitemap, then the values or part of the values are not visible.
Here is a screenshot of my sitemap in the iOS app view:
You can see the following cases:
- partly visible value (e.g. without unit): Außentemperatur (BT1)
- invisible value: Berechnete Vorlauftemperat…
- fully visible value: Gradminuten
For me it would be fine if only the label gets truncated, but the value and its unit should always be visible.
Has anyone an idea, if this is some kind of configurable?
Thanks!
Jonathan
