on either of my iphone or ipad app is webview and image working on sitemap. Via webpage it’s everything OK, but application is not showing anything.
For example I do have this section
Frame label="Tests" {
Text label="click me" {
Text label="testing"
Webview url="/static/shaddow.svg?{{itemValue('Sun_Azimuth')}}" icon="none"
Image refresh=60000 url="http://10.10.1.11:3000/render/d-solo/2qN8-ZCZk/openhab?orgId=1&theme=dark&panelId=2&from=now-12h&to=now&refresh=30s&width=1000&height=100"
<< Ok, i read a little to fast, you are allready using webviews. then you are probably awhere of my solution. Still i think grafana graphs are easier in html file.>>
Hello Kriznik,
This is a known issue, try to show the graphs trough webview.
Like this:
Create a html file with url from grafana (or whatever image you want to get from the internet)
I have actually setup a new openhab installation on Ubuntu LTS 20.04 with grafana 7.0. In Basic UI the grafana chart is shown. However, in the ios app not. I’m using the rendering option to display it as an image.
I still have my old openhab installation running with another local IP adress. If I change the settings in the ios app to the old installation the grafana charts still displayed. So I don’t think it’s related to the ios app. Any ideas on that topic?
