IoS App Testflight issues
I am running the testflight version 3.4.33(330)
Ipad
Ipados 27.0.1
I can separately log each of these as a bug just not sure if the are known/expected
  1. the top part screen appers to be obscured by a blurred section
  2. when editing yaml or rules it if very difficult to select text
    When you double click(tap) and to select a word then try to move the selection rails it is very
    difficult and will normally only work in one direction, but its not consistent
  3. the new menu system(see screenshot) ( the circle with 3 …) is cumbersome to use
    A) the selecting of an item (e.g. save appears sometimes to miss the selection and the menu just goes away
    B) this is also now multiple taps for something a simple as save (i personally prefer the exiting web menus and the old ios.
