iOS: No push notifications, including myopenHAB device tests — notifications visible in app
Hi everyone,
Since updating my server to openHAB 5.2.3, I no longer receive push notifications on my iPhone. The iOS app was unchanged when the problem started. I use the latest TestFlight version.
Versions
  • openHAB: 5.2.3
  • iOS app / TestFlight build: 3.3.11 (313)
  • iOS: 27.0.1
  • iPhone model: [please add]
Symptoms
  • Notifications appear in the notification history on myopenhab.org.
  • They also appear when I manually open the notification list in the iOS app.
  • No push notification appears when the iPhone is locked.
  • The usual in-app notification banner is also missing when the app is open.
  • A test notification sent directly from myopenHAB → Devices appears in the history but does not trigger a push notification either.
Already tried
  • Removed and re-registered the iPhone in myopenHAB.
  • Restarted the iPhone.
  • Tested both Wi-Fi and 5G.
  • Confirmed that iOS notifications are enabled for openHAB.
None of these steps helped.
Is anyone else experiencing this? Is there a way to check whether the app successfully registers its push token, or whether myopenHAB encounters an error when sending to Apple Push Notification service?
cheers
Andreas
so here are the steps, which brought my push notifications back:
ok… so I did:
  • disabling Messages for opanHAB iOS app in the iOS settings
  • uninstalling the iOS app
  • restarting iPhone
  • deleting device out of myopenhab.org device list
  • installed the TestFlight alpha version
  • configured everything I the right way again and accept all questions about Messaging and LAN access with yes.
