I need the iotivity 1.0.0 bindings for OpenHab 2.
Yes, actually my main goal is to binding Iotivity 1.0.0 with OpenHab2. But at the iotivity side they are using cbor instead of JSON. So, it is throwing the exceptions.
I also tried with iotivity ver. 0.9.1 but there I am getting “java.lang.NullPointerException” at the OpenHab2 side.
at org.eclipse.smarthome.binding.iotivity.discovery.IoTivityDiscoveryService$1.onResponse(IoTivityDiscoveryService.java:148)
at org.eclipse.californium.core.coap.Request.setResponse(Request.java:361)
at org.eclipse.californium.core.network.EndpointManager$ClientMessageDeliverer.deliverResponse(EndpointManager.java:251)
at org.eclipse.californium.core.network.stack.CoapStack$StackTopAdapter.receiveResponse(CoapStack.java:191)
at org.eclipse.californium.core.network.stack.AbstractLayer.receiveResponse(AbstractLayer.java:98)
at org.eclipse.californium.core.network.stack.ObserveLayer.receiveResponse(ObserveLayer.java:137)
at org.eclipse.californium.core.network.stack.BlockwiseLayer.receiveResponse(BlockwiseLayer.java:285)
at org.eclipse.californium.core.network.stack.TokenLayer.receiveResponse(TokenLayer.java:79)
at org.eclipse.californium.core.network.stack.ReliabilityLayer.receiveResponse(ReliabilityLayer.java:247)
at org.eclipse.californium.core.network.stack.CoapStack.receiveResponse(CoapStack.java:138)
at org.eclipse.californium.core.network.CoAPEndpoint$InboxImpl.receiveMessage(CoAPEndpoint.java:615)
at org.eclipse.californium.core.network.CoAPEndpoint$InboxImpl.access$700(CoAPEndpoint.java:526)
at org.eclipse.californium.core.network.CoAPEndpoint$InboxImpl$1.run(CoAPEndpoint.java:538)
at org.eclipse.californium.core.network.CoAPEndpoint$5.run(CoAPEndpoint.java:670)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:178)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:292)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
@Anindya_Sundar_Gayen, I missed your post in December, just stumbled now over it.
Did you make any progress on the Iotivity binding? Do you have your sources on a github fork, so that I could have a look?
Cheers,
Kai
is there any other update for IoTivity binding?
