I have multiple Amazon Echo devices, and a HomeMatic Automation System.
Now, I want to say “turn on the TV”, and based on the room the correct TV should switch on.
The room can be identified by the Amazon echo device IP…
as far as I understand, you are using the Hue emulation?
I dont think IP Filtering is possible here, but you can The following:
Name 2 Switch Items “TV” and tag it as switchable ( [ “Switchable” ] ).
Let Echo discover both items and delete one of them, depending on the Room and which TV should be switched.
