I’ve been getting these errors (only during startup of OH) below since 4.3.0, was wondering if this is just a one off. Both DVR and Pi4 have correct time based on NTP.
2025-05-08 12:27:53.966 [WARN ] [ab.binding.ipcamera.internal.onvif.OnvifConnection] - ONVIF time in camera does not match openHAB's time, this can cause authentication issues as ONVIF requires the time to be close to each other
2025-05-08 12:27:57.537 [WARN ] [ab.binding.ipcamera.internal.onvif.OnvifConnection] - ONVIF time in camera does not match openHAB's time, this can cause authentication issues as ONVIF requires the time to be close to each other
2025-05-08 12:27:57.768 [WARN ] [ab.binding.ipcamera.internal.onvif.OnvifConnection] - ONVIF time in camera does not match openHAB's time, this can cause authentication issues as ONVIF requires the time to be close to each other
2025-05-08 12:28:07.882 [WARN ] [ab.binding.ipcamera.internal.onvif.OnvifConnection] - ONVIF time in camera does not match openHAB's time, this can cause authentication issues as ONVIF requires the time to be close to each other
2025-05-08 12:28:12.904 [WARN ] [ab.binding.ipcamera.internal.onvif.OnvifConnection] - ONVIF time in camera does not match openHAB's time, this can cause authentication issues as ONVIF requires the time to be close to each other
2025-05-08 12:28:18.529 [WARN ] [ab.binding.ipcamera.internal.onvif.OnvifConnection] - ONVIF time in camera does not match openHAB's time, this can cause authentication issues as ONVIF requires the time to be close to each other
2025-05-08 12:28:18.882 [WARN ] [ab.binding.ipcamera.internal.onvif.OnvifConnection] - ONVIF time in camera does not match openHAB's time, this can cause authentication issues as ONVIF requires the time to be close to each other
2025-05-08 12:28:20.408 [WARN ] [ab.binding.ipcamera.internal.onvif.OnvifConnection] - ONVIF time in camera does not match openHAB's time, this can cause authentication issues as ONVIF requires the time to be close to each other
Best, Jay
