IpCamera does not bind anymore after update
I am using openhab 4.0.1 on a windows PC. Now I have an IP-Camera which I would like to connect with the IP_Camera binding Version 4.0.1.
After implemented the Thing I get an error message as follows:
2023-08-31 18:27:37.064 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.thingUpdated()' on 'org.openhab.binding.ipcamera.internal.handler.IpCameraHandler@4c9da75c': Alias "/ipcamera/IP_Cam_OG" was never registered by org.openhab.binding.ipcamera_4.0.0.202303221120 [27]
java.lang.RuntimeException: Alias "/ipcamera/IP_Cam_OG" was never registered by org.openhab.binding.ipcamera_4.0.0.202303221120 [27]
	at org.ops4j.pax.web.service.internal.HttpServiceEnabled.lambda$doUnregisterServlet$2(HttpServiceEnabled.java:703) ~[?:?]
	at org.ops4j.pax.web.service.spi.model.ServerModel.lambda$run$2(ServerModel.java:541) ~[?:?]
	at java.util.concurrent.CompletableFuture$AsyncSupply.run(CompletableFuture.java:1768) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
	at java.lang.Thread.run(Thread.java:833) ~[?:?]
	Suppressed: java.lang.Throwable
		at org.ops4j.pax.web.service.spi.model.ServerModel.run(ServerModel.java:535) ~[?:?]
		at org.ops4j.pax.web.service.internal.HttpServiceEnabled.doUnregisterServlet(HttpServiceEnabled.java:585) ~[?:?]
		at org.ops4j.pax.web.service.internal.HttpServiceEnabled.unregister(HttpServiceEnabled.java:545) ~[?:?]
		at org.ops4j.pax.web.service.internal.HttpServiceProxy.unregister(HttpServiceProxy.java:186) ~[?:?]
		at org.openhab.binding.ipcamera.internal.servlet.IpCameraServlet.dispose(IpCameraServlet.java:136) ~[?:?]
		at org.openhab.binding.ipcamera.internal.servlet.CameraServlet.dispose(CameraServlet.java:283) ~[?:?]
		at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.dispose(IpCameraHandler.java:1863) ~[?:?]
		at org.openhab.core.thing.binding.BaseThingHandler.thingUpdated(BaseThingHandler.java:153) ~[?:?]
		at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?]
		at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?]
		at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:147) ~[?:?]
		at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) ~[?:?]
Caused by: java.lang.IllegalArgumentException: Alias "/ipcamera/IP_Cam_OG" was never registered by org.openhab.binding.ipcamera_4.0.0.202303221120 [27]
	at org.ops4j.pax.web.service.internal.HttpServiceEnabled.lambda$doUnregisterServlet$2(HttpServiceEnabled.java:612) ~[?:?]
The URL Link with password works and I tested it in the browser. Can someone tell me what I am doing wrong?
The log seems to show it fails when it is setting up or removing the servlet. What primary network address is selected in openHAB’s settings and is it a valid, working and non restricted network? Look at why it may fail to talk with that network address range. Not much to go on besides this.
A good point. I checked and there was no primary network selected. But also when I check the primary network it does not work. On the other hand I do have another IP-Cam in the SAME network and that one works.
If I paste from openhab the URL (with PW) into a browser page of the same windows server, I can see the video stream. The only thing which does not work is when using the MJPEG URL Item in a widget :frowning:
Other ideas to check? I am using OH 4.1.0.M1 Windows
post some TRACE level log output. If you dont know how, read the very first paragraph of the ipcamera documentation.
[DEBUG] [amera.internal.servlet.CameraServlet] - GET:/ipcamera.mjpeg, received from 192.xxx.yyy.6
[DEBUG] [amera.internal.servlet.CameraServlet] - First stream requested, opening up stream from camera
[TRACE] [era.internal.handler.IpCameraHandler] - Sending camera: GET: http://192.xxx.yyy.17:80/mjpg/video.mjpg
[DEBUG] [era.internal.handler.IpCameraHandler] - Setting Content-Type to:multipart/x-mixed-replace; boundary="myboundary"
[DEBUG] [amera.internal.servlet.CameraServlet] - Now there are 0 ipcamera.mjpeg streams open.
[DEBUG] [amera.internal.servlet.CameraServlet] - All ipcamera.mjpeg streams have stopped.
[WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: undefined
I have two cameras:
Camera http://192.xxx.yyy.17:80/mjpg/video.mjpg is working
Camera 192.xxx.yyy.6 is NOT working
The problem I see is that such camera with the IP ending .6 does not exist! But I can not find any IP entry with this address at all!
Question: How can I do a search over all Items, Things to find it?
