boogie
(Christoph)
August 3, 2021, 7:39pm
2435
Hello @matt1 unfortunately, i have a problem with my Instar 9020 FullHD camera. As soon as i want to approach a position - i get the following error message:
21:23:26.984 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'cam_garden_preset' received command 1
21:23:27.001 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'cam_garden_preset' predicted to become 1
21:23:27.012 [WARN ] [camera.internal.onvif.OnvifConnection] - Camera did not report any ONVIF preset locations, updating preset tokens now.
21:23:27.033 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'cam_garden_preset' changed from 2 to 1
21:23:27.023 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.ipcamera.internal.handler.IpCameraHandler@11cf1f1': Index: 0, Size: 0
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.LinkedList.checkElementIndex(LinkedList.java:559) ~[?:?]
at java.util.LinkedList.get(LinkedList.java:480) ~[?:?]
at org.openhab.binding.ipcamera.internal.onvif.OnvifConnection.getXml(OnvifConnection.java:287) ~[?:?]
at org.openhab.binding.ipcamera.internal.onvif.OnvifConnection.requestBuilder(OnvifConnection.java:365) ~[?:?]
at org.openhab.binding.ipcamera.internal.onvif.OnvifConnection.sendPTZRequest(OnvifConnection.java:808) ~[?:?]
at org.openhab.binding.ipcamera.internal.onvif.OnvifConnection.gotoPreset(OnvifConnection.java:561) ~[?:?]
at org.openhab.binding.ipcamera.internal.handler.IpCameraHandler.handleCommand(IpCameraHandler.java:1301) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy213.handleCommand(Unknown Source) [?:?]
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:80) [bundleFile:?]
at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Which is a bit strange, because i have another model in use (Instar 8015 FullHD). With this camera i can control the positions without any problems from the OH user interface.
I know this line sounds like i havenāt set any positions, but there are some stored and with the Instar-app, these positions can be controlled.
This is my log file as soon as i activate the camera:
21:23:58.225 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:instar:cam_garden' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
21:24:03.305 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:instar:cam_garden' changed from UNINITIALIZED (DISABLED) to INITIALIZING
21:24:03.339 [DEBUG] [mera.internal.handler.IpCameraHandler] - File server for camera at 192.168.1.111 has started on port 8082 for all NIC's.
21:24:03.349 [DEBUG] [mera.internal.handler.IpCameraHandler] - Setting up the Alarm Server settings in the camera now
21:24:03.372 [DEBUG] [camera.internal.onvif.OnvifConnection] - Camera is not reachable on ONVIF port:54321 or the port may be wrong.
21:24:03.374 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:instar:cam_garden' changed from INITIALIZING to ONLINE
21:24:03.388 [DEBUG] [.ipcamera.internal.MyNettyAuthHandler] - Setting up the camera to use Basic Auth and resending last request with correct auth.
The ports match in the camera and in the binding, the camera is on the local network.
Do you have an idea what it could be about?
matt1
(Skinah)
August 4, 2021, 12:51am
2436
I saw it happen with my Instar 8015 a few days ago and have not had time to look into this, however I suspect if you pause the camera and then unpause it to force the thing to reconnect that the problem wont exist until the camera drops offline next. See if that gets you running until I have a chance to look and let me know either way.
I also would not recommend you change the default ONVIF port on the camera, that could mean tech support may have a harder time helping you, leave it on the default port number.
The debug log will print the command that it is using to start ffmpeg with. Copy and paste it into a terminal/command and run it manually and see what ffmpeg says and you can then trial the settings this way which you may find easier.
FFmpeg has whats called INPUT options that are applied to the input stream and OUTPUT options that are applied to its jpg output file. Knowing the correct option and if it needs to go at the input or output side is important.
matt1
(Skinah)
August 6, 2021, 3:17am
2437
That would explain it. Iām guessing the time I saw it occur I sent a PTZ preset change when the camera was still rebooting as that looks to be the only way it can happen if the camera has come online but it has not yet completed a sucessful ONVIF connection. In your case it may be a firewall blocking that port so the ONVIF canāt connect. To see more you really need to use TRACE mode and it needs to be when the camera is first connecting as I need to see the onvif replies to see if any succeed and if it fails at a certain point.
boogie
(Christoph)
August 6, 2021, 12:53pm
2438
Hi @matt1 thanks for your help!
I already tried it with the 8080 port, meanwhile i changed it back to the 8080 port.
According to the TRACE logfile, it seems that the user or password is wrong, i checked, the password is correct. I even tried to set the default Instar-password (no special characters or anything else), but I always get the following message:
14:48:06.914 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'ipcamera:instar:cam_garden' changed from OFFLINE (CONFIGURATION_ERROR): Exception when starting server. Try changing the Server Port to another number. to ONLINE
14:48:06.925 [DEBUG] [camera.internal.onvif.OnvifConnection] - Camera is not reachable on ONVIF port:8080 or the port may be wrong.
14:48:06.944 [DEBUG] [.ipcamera.internal.MyNettyAuthHandler] - Setting up the camera to use Basic Auth and resending last request with correct auth.
14:48:06.966 [TRACE] [mera.internal.handler.IpCameraHandler] - Sending camera: GET: http://192.168.1.111:80/param.cgi?cmd=setmdalarm&-aname=server2&-switch=on&-interval=1&cmd=setalarmserverattr&-as_index=3&-as_server=192.168.1.101&-as_port=8082&-as_path=/instar&-as_queryattr1=&-as_queryval1=&-as_queryattr2=&-as_queryval2=&-as_queryattr3=&-as_queryval3=&-as_activequery=1&-as_auth=0&-as_query1=0&-as_query2=0&-as_query3=0
14:48:06.964 [TRACE] [mera.internal.handler.IpCameraHandler] - HTTP Result back from camera is :<html>
<head>
<title>Login</title>
<meta content="text/html"; charset="utf-8" http-equiv="content-type">
<META HTTP-EQUIV="Content-Script-Type" CONTENT="text/javascript">
<META http-equiv="Pragma" CONTENT="no-cache">
<META HTTP-EQUIV="Cache-Control" CONTENT="no-cache">
<meta HTTP-EQUIV="Expires" CONTENT="Fri, 06 Aug 2021 12:48:06 GMT">
</head>
<body>
Error: username or password error,please input again.
</body>
</html>
14:48:07.015 [TRACE] [mera.internal.handler.IpCameraHandler] - HTTP Result back from camera is :[Succeed]set ok.:
14:48:07.923 [TRACE] [mera.internal.handler.IpCameraHandler] - Sending camera: GET: http://192.168.1.111:80/tmpfs/snap.jpg
14:48:10.921 [DEBUG] [mera.internal.handler.IpCameraHandler] - About to connect to the IP Camera using the ONVIF PORT at IP:192.168.1.111:8080
14:48:10.926 [TRACE] [camera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSystemDateAndTime
14:48:10.946 [TRACE] [mera.internal.handler.IpCameraHandler] - Sending camera: GET: http://192.168.1.111:80/tmpfs/snap.jpg
14:48:10.947 [DEBUG] [camera.internal.onvif.OnvifConnection] - Camera is not reachable on ONVIF port:8080 or the port may be wrong.
14:48:14.459 [WARN ] [b.core.thing.binding.BaseThingHandler] - Handler IpCameraHandler of thing ipcamera:instar:cam_garden tried updating channel motionAlarm although the handler was already disposed.
14:48:14.463 [TRACE] [mera.internal.handler.IpCameraHandler] - Sending camera: GET: http://192.168.1.111:80/tmpfs/snap.jpg
14:48:14.466 [WARN ] [b.core.thing.binding.BaseThingHandler] - Handler IpCameraHandler of thing ipcamera:instar:cam_garden tried updating channel pirAlarm although the handler was already disposed.
14:48:14.472 [WARN ] [b.core.thing.binding.BaseThingHandler] - Handler IpCameraHandler of thing ipcamera:instar:cam_garden tried updating channel audioAlarm although the handler was already disposed.
14:48:14.479 [DEBUG] [.ipcamera.internal.MyNettyAuthHandler] - Setting up the camera to use Basic Auth and resending last request with correct auth.
I also followed the hint with the firewall, but there is no firewall between camera and openHAB and both devices are in the same subnet.
matt1
(Skinah)
August 6, 2021, 2:32pm
2439
That message about user/pass is from before the binding has setup for BASIC authās so you can ignore it if it only happens once and then no more times after that.
With ONVIF the spec states that GetSystemDateAndTime will not require a valid user/pass to get a response so this also confirms that something is blocking the camera. NVR, firewall, your running it in docker, or something must be blocking it. Does the camera work with āonvif device managerā program? Check for firmware updates and contact their support.
Have you tried restarting both openHAB and the camera?
EDIT: @boogie I have done some fixes to stop the ERROR you reported, but this will not make a camera that is not talking magically connect so donāt expect this to solve your problem.
[ipcamera] Fix bugs, IndexOutOfBoundsException and remove sleep. by Skinah Ā· Pull Request #11089 Ā· openhab/openhab-addons (github.com)
Hi, itās me, again
It seems in my system the binding is lost connection with camera after hours of working. Here is the openhab.log, from 21:09 the binding was stopped until 21:43 when I disable and re-enable the binding in admin page:
2021-08-10 21:09:49.015 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:09:49.052 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:10:47Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:09:47Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:09:49.053 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:09:58.073 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:09:56Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:10:47Z</tev:TerminationTime></tev:PullMessagesResponse></s:Body></s:Envelope>
2021-08-10 21:09:58.075 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:09:58.140 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:10:57Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:09:57Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:09:58.141 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:39:44.349 [DEBUG] [pcamera.internal.StreamServerHandler] - Stream Server recieved request GET:/ipcamera.gif
2021-08-10 21:39:45.726 [DEBUG] [pcamera.internal.StreamServerHandler] - Stream Server recieved request GET:/ipcamera.gif
2021-08-10 21:43:43.798 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Unsubscribe
2021-08-10 21:43:43.836 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsrf-bf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery"><s:Body><s:Fault><s:Code><s:Value>s:Sender</s:Value><s:Subcode><s:Value>ter:ActionNotSupported</s:Value><s:Subcode><s:Value>ter:NotImplemented</s:Value></s:Subcode></s:Subcode></s:Code><s:Reason><s:Text xml:lang="en">This optional method is not implemented</s:Text></s:Reason></s:Fault></s:Body></s:Envelope>
2021-08-10 21:43:50.071 [DEBUG] [era.internal.handler.IpCameraHandler] - File server for camera at 192.168.0.214 has started on port 54321 for all NIC's.
2021-08-10 21:43:50.126 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSystemDateAndTime
2021-08-10 21:43:50.159 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tds="http://www.onvif.org/ver10/device/wsdl"><s:Header></s:Header><s:Body><tds:GetSystemDateAndTimeResponse><tds:SystemDateAndTime><tt:DateTimeType>Manual</tt:DateTimeType><tt:DaylightSavings>false</tt:DaylightSavings><tt:TimeZone><tt:TZ>GMT+07:00</tt:TZ></tt:TimeZone><tt:UTCDateTime><tt:Time><tt:Hour>14</tt:Hour><tt:Minute>43</tt:Minute><tt:Second>47</tt:Second></tt:Time><tt:Date><tt:Year>2021</tt:Year><tt:Month>8</tt:Month><tt:Day>10</tt:Day></tt:Date></tt:UTCDateTime></tds:SystemDateAndTime></tds:GetSystemDateAndTimeResponse></s:Body></s:Envelope>
2021-08-10 21:43:50.160 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetCapabilities
2021-08-10 21:43:50.166 [DEBUG] [amera.internal.onvif.OnvifConnection] - Cameras UTC dateTime is:2021-8-10T14:43:47
2021-08-10 21:43:50.167 [DEBUG] [amera.internal.onvif.OnvifConnection] - Openhabs UTC dateTime is:2021-08-10T14:43:50.167Z
2021-08-10 21:43:50.212 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tds="http://www.onvif.org/ver10/device/wsdl"><s:Body><tds:GetCapabilitiesResponse><tds:Capabilities><tt:Device><tt:XAddr>http://192.168.0.214/onvif/device_service</tt:XAddr><tt:Network><tt:IPFilter>false</tt:IPFilter><tt:IPVersion6>false</tt:IPVersion6><tt:DynDNS>false</tt:DynDNS><tt:Extension><tt:Dot11Configuration>false</tt:Dot11Configuration></tt:Extension></tt:Network><tt:System><tt:DiscoveryResolve>false</tt:DiscoveryResolve><tt:DiscoveryBye>true</tt:DiscoveryBye><tt:RemoteDiscovery>false</tt:RemoteDiscovery><tt:SystemBackup>false</tt:SystemBackup><tt:SystemLogging>false</tt:SystemLogging><tt:FirmwareUpgrade>false</tt:FirmwareUpgrade><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>00</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>10</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>20</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>30</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>40</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>42</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>16</tt:Major><tt:Minor>12</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>18</tt:Major><tt:Minor>06</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>18</tt:Major><tt:Minor>12</tt:Minor></tt:SupportedVersions><tt:Extension><tt:HttpFirmwareUpgrade>false</tt:HttpFirmwareUpgrade><tt:HttpSystemBackup>false</tt:HttpSystemBackup><tt:HttpSystemLogging>false</tt:HttpSystemLogging><tt:HttpSupportInformation>false</tt:HttpSupportInformation></tt:Extension></tt:System><tt:IO><tt:InputConnectors>0</tt:InputConnectors><tt:RelayOutputs>0</tt:RelayOutputs></tt:IO><tt:Security><tt:TLS1.1>false</tt:TLS1.1><tt:TLS1.2>false</tt:TLS1.2><tt:OnboardKeyGeneration>false</tt:OnboardKeyGeneration><tt:AccessPolicyConfig>false</tt:AccessPolicyConfig><tt:X.509Token>false</tt:X.509Token><tt:SAMLToken>false</tt:SAMLToken><tt:KerberosToken>false</tt:KerberosToken><tt:RELToken>false</tt:RELToken><tt:Extension><tt:TLS1.0>false</tt:TLS1.0><tt:Extension><tt:Dot1X>false</tt:Dot1X><tt:SupportedEAPMethod>0</tt:SupportedEAPMethod><tt:RemoteUserHandling>false</tt:RemoteUserHandling></tt:Extension></tt:Extension></tt:Security></tt:Device><tt:Events><tt:XAddr>http://192.168.0.214/onvif/event_service</tt:XAddr><tt:WSSubscriptionPolicySupport>true</tt:WSSubscriptionPolicySupport><tt:WSPullPointSupport>true</tt:WSPullPointSupport><tt:WSPausableSubscriptionManagerInterfaceSupport>false</tt:WSPausableSubscriptionManagerInterfaceSupport></tt:Events><tt:Imaging><tt:XAddr>http://192.168.0.214/onvif/imaging_service</tt:XAddr></tt:Imaging><tt:Media><tt:XAddr>http://192.168.0.214/onvif/media_service</tt:XAddr><tt:StreamingCapabilities><tt:RTPMulticast>false</tt:RTPMulticast><tt:RTP_TCP>true</tt:RTP_TCP><tt:RTP_RTSP_TCP>true</tt:RTP_RTSP_TCP></tt:StreamingCapabilities><tt:Extension><tt:ProfileCapabilities><tt:MaximumNumberOfProfiles>6</tt:MaximumNumberOfProfiles></tt:ProfileCapabilities></tt:Extension></tt:Media><tt:Extension><tt:DeviceIO><tt:XAddr>http://192.168.0.214/onvif/deviceIO_service</tt:XAddr><tt:VideoSources>1</tt:VideoSources><tt:VideoOutputs>0</tt:VideoOutputs><tt:AudioSources>0</tt:AudioSources><tt:AudioOutputs>0</tt:AudioOutputs><tt:RelayOutputs>0</tt:RelayOutputs><tt:SerialPorts>0</tt:SerialPorts><tt:DigitalInputs>0</tt:DigitalInputs></tt:DeviceIO></tt:Extension></tds:Capabilities></tds:GetCapabilitiesResponse></s:Body></s:Envelope>
2021-08-10 21:43:50.214 [DEBUG] [amera.internal.onvif.OnvifConnection] - deviceXAddr:/onvif/device_service
2021-08-10 21:43:50.215 [DEBUG] [amera.internal.onvif.OnvifConnection] - eventsXAddr:/onvif/event_service
2021-08-10 21:43:50.216 [DEBUG] [amera.internal.onvif.OnvifConnection] - mediaXAddr:/onvif/media_service
2021-08-10 21:43:50.217 [DEBUG] [amera.internal.onvif.OnvifConnection] - We hit an issue parsing url:
2021-08-10 21:43:50.218 [TRACE] [amera.internal.onvif.OnvifConnection] - Camera must not support PTZ, it failed to give a <tt:PTZ><tt:XAddr>:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tds="http://www.onvif.org/ver10/device/wsdl"><s:Body><tds:GetCapabilitiesResponse><tds:Capabilities><tt:Device><tt:XAddr>http://192.168.0.214/onvif/device_service</tt:XAddr><tt:Network><tt:IPFilter>false</tt:IPFilter><tt:IPVersion6>false</tt:IPVersion6><tt:DynDNS>false</tt:DynDNS><tt:Extension><tt:Dot11Configuration>false</tt:Dot11Configuration></tt:Extension></tt:Network><tt:System><tt:DiscoveryResolve>false</tt:DiscoveryResolve><tt:DiscoveryBye>true</tt:DiscoveryBye><tt:RemoteDiscovery>false</tt:RemoteDiscovery><tt:SystemBackup>false</tt:SystemBackup><tt:SystemLogging>false</tt:SystemLogging><tt:FirmwareUpgrade>false</tt:FirmwareUpgrade><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>00</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>10</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>20</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>30</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>40</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>2</tt:Major><tt:Minor>42</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>16</tt:Major><tt:Minor>12</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>18</tt:Major><tt:Minor>06</tt:Minor></tt:SupportedVersions><tt:SupportedVersions><tt:Major>18</tt:Major><tt:Minor>12</tt:Minor></tt:SupportedVersions><tt:Extension><tt:HttpFirmwareUpgrade>false</tt:HttpFirmwareUpgrade><tt:HttpSystemBackup>false</tt:HttpSystemBackup><tt:HttpSystemLogging>false</tt:HttpSystemLogging><tt:HttpSupportInformation>false</tt:HttpSupportInformation></tt:Extension></tt:System><tt:IO><tt:InputConnectors>0</tt:InputConnectors><tt:RelayOutputs>0</tt:RelayOutputs></tt:IO><tt:Security><tt:TLS1.1>false</tt:TLS1.1><tt:TLS1.2>false</tt:TLS1.2><tt:OnboardKeyGeneration>false</tt:OnboardKeyGeneration><tt:AccessPolicyConfig>false</tt:AccessPolicyConfig><tt:X.509Token>false</tt:X.509Token><tt:SAMLToken>false</tt:SAMLToken><tt:KerberosToken>false</tt:KerberosToken><tt:RELToken>false</tt:RELToken><tt:Extension><tt:TLS1.0>false</tt:TLS1.0><tt:Extension><tt:Dot1X>false</tt:Dot1X><tt:SupportedEAPMethod>0</tt:SupportedEAPMethod><tt:RemoteUserHandling>false</tt:RemoteUserHandling></tt:Extension></tt:Extension></tt:Security></tt:Device><tt:Events><tt:XAddr>http://192.168.0.214/onvif/event_service</tt:XAddr><tt:WSSubscriptionPolicySupport>true</tt:WSSubscriptionPolicySupport><tt:WSPullPointSupport>true</tt:WSPullPointSupport><tt:WSPausableSubscriptionManagerInterfaceSupport>false</tt:WSPausableSubscriptionManagerInterfaceSupport></tt:Events><tt:Imaging><tt:XAddr>http://192.168.0.214/onvif/imaging_service</tt:XAddr></tt:Imaging><tt:Media><tt:XAddr>http://192.168.0.214/onvif/media_service</tt:XAddr><tt:StreamingCapabilities><tt:RTPMulticast>false</tt:RTPMulticast><tt:RTP_TCP>true</tt:RTP_TCP><tt:RTP_RTSP_TCP>true</tt:RTP_RTSP_TCP></tt:StreamingCapabilities><tt:Extension><tt:ProfileCapabilities><tt:MaximumNumberOfProfiles>6</tt:MaximumNumberOfProfiles></tt:ProfileCapabilities></tt:Extension></tt:Media><tt:Extension><tt:DeviceIO><tt:XAddr>http://192.168.0.214/onvif/deviceIO_service</tt:XAddr><tt:VideoSources>1</tt:VideoSources><tt:VideoOutputs>0</tt:VideoOutputs><tt:AudioSources>0</tt:AudioSources><tt:AudioOutputs>0</tt:AudioOutputs><tt:RelayOutputs>0</tt:RelayOutputs><tt:SerialPorts>0</tt:SerialPorts><tt:DigitalInputs>0</tt:DigitalInputs></tt:DeviceIO></tt:Extension></tds:Capabilities></tds:GetCapabilitiesResponse></s:Body></s:Envelope>
2021-08-10 21:43:50.219 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetProfiles
2021-08-10 21:43:50.292 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tt="http://www.onvif.org/ver10/schema"><s:Body><trt:GetProfilesResponse><trt:Profiles token="Profile000" fixed="true"><tt:Name>Profile000</tt:Name><tt:VideoSourceConfiguration token="VideoSource000"><tt:Name>VideoSource000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>VideoSource000</tt:SourceToken><tt:Bounds x="0" y="0" width="1920" height="1080"></tt:Bounds></tt:VideoSourceConfiguration><tt:VideoEncoderConfiguration token="VideoEncoder000"><tt:Name>VideoEncoder000</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H265</tt:Encoding><tt:Resolution><tt:Width>1920</tt:Width><tt:Height>1080</tt:Height></tt:Resolution><tt:Quality>6.000000</tt:Quality><tt:RateControl><tt:FrameRateLimit>25</tt:FrameRateLimit><tt:EncodingInterval>1</tt:EncodingInterval><tt:BitrateLimit>4096</tt:BitrateLimit></tt:RateControl><tt:H265><tt:GovLength>50</tt:GovLength><tt:H265Profile>Main</tt:H265Profile></tt:H265><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.2.4</tt:IPv4Address></tt:Address><tt:Port>40000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:MetadataConfiguration token="Metadata000" CompressionType="None" GeoLocation="false"><tt:Name>Metadata000</tt:Name><tt:UseCount>1</tt:UseCount><tt:PTZStatus><tt:Status>false</tt:Status><tt:Position>false</tt:Position></tt:PTZStatus><tt:Events><tt:Filter><wsnt:TopicExpression Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tns1="http://www.onvif.org/ver10/topics">tns1:Media/ConfigurationChanged</wsnt:TopicExpression></tt:Filter></tt:Events><tt:Analytics>true</tt:Analytics><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.2.4</tt:IPv4Address></tt:Address><tt:Port>40000</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:MetadataConfiguration></trt:Profiles><trt:Profiles token="Profile001" fixed="true"><tt:Name>Profile001</tt:Name><tt:VideoSourceConfiguration token="VideoSource000"><tt:Name>VideoSource000</tt:Name><tt:UseCount>2</tt:UseCount><tt:SourceToken>VideoSource000</tt:SourceToken><tt:Bounds x="0" y="0" width="1920" height="1080"></tt:Bounds></tt:VideoSourceConfiguration><tt:VideoEncoderConfiguration token="VideoEncoder001"><tt:Name>VideoEncoder001</tt:Name><tt:UseCount>1</tt:UseCount><tt:Encoding>H264</tt:Encoding><tt:Resolution><tt:Width>640</tt:Width><tt:Height>480</tt:Height></tt:Resolution><tt:Quality>4.000000</tt:Quality><tt:RateControl><tt:FrameRateLimit>10</tt:FrameRateLimit><tt:EncodingInterval>1</tt:EncodingInterval><tt:BitrateLimit>896</tt:BitrateLimit></tt:RateControl><tt:H264><tt:GovLength>20</tt:GovLength><tt:H264Profile>Main</tt:H264Profile></tt:H264><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.2.4</tt:IPv4Address></tt:Address><tt:Port>40016</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:VideoEncoderConfiguration><tt:MetadataConfiguration token="Metadata001" CompressionType="None" GeoLocation="false"><tt:Name>Metadata001</tt:Name><tt:UseCount>1</tt:UseCount><tt:PTZStatus><tt:Status>false</tt:Status><tt:Position>false</tt:Position></tt:PTZStatus><tt:Events><tt:Filter><wsnt:TopicExpression Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tns1="http://www.onvif.org/ver10/topics">tns1:Media/ConfigurationChanged</wsnt:TopicExpression></tt:Filter></tt:Events><tt:Analytics>true</tt:Analytics><tt:Multicast><tt:Address><tt:Type>IPv4</tt:Type><tt:IPv4Address>224.1.2.4</tt:IPv4Address></tt:Address><tt:Port>40016</tt:Port><tt:TTL>64</tt:TTL><tt:AutoStart>false</tt:AutoStart></tt:Multicast><tt:SessionTimeout>PT60S</tt:SessionTimeout></tt:MetadataConfiguration></trt:Profiles></trt:GetProfilesResponse></s:Body></s:Envelope>
2021-08-10 21:43:50.294 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:Profile000
2021-08-10 21:43:50.296 [TRACE] [amera.internal.onvif.OnvifConnection] - String was found:Profile001
2021-08-10 21:43:50.298 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetSnapshotUri
2021-08-10 21:43:50.302 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetStreamUri
2021-08-10 21:43:50.305 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetEventProperties
2021-08-10 21:43:50.308 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:GetServiceCapabilities
2021-08-10 21:43:50.388 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsrf-bf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery"><s:Body><s:Fault><s:Code><s:Value>s:Sender</s:Value><s:Subcode><s:Value>ter:ActionNotSupported</s:Value><s:Subcode><s:Value>ter:NotImplemented</s:Value></s:Subcode></s:Subcode></s:Code><s:Reason><s:Text xml:lang="en">This optional method is not implemented</s:Text></s:Reason></s:Fault></s:Body></s:Envelope>
2021-08-10 21:43:50.430 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsrf-bf="http://docs.oasis-open.org/wsrf/bf-2" xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery"><s:Body><s:Fault><s:Code><s:Value>s:Sender</s:Value><s:Subcode><s:Value>ter:ActionNotSupported</s:Value><s:Subcode><s:Value>ter:NotImplemented</s:Value></s:Subcode></s:Subcode></s:Code><s:Reason><s:Text xml:lang="en">This optional method is not implemented</s:Text></s:Reason></s:Fault></s:Body></s:Envelope>
2021-08-10 21:43:50.448 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:tt="http://www.onvif.org/ver10/schema"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/EventPortType/GetEventPropertiesResponse</wsa5:Action></s:Header><s:Body><tev:GetEventPropertiesResponse><tev:TopicNamespaceLocation>http://www.onvif.org/onvif/ver10/topics/topicns.xml</tev:TopicNamespaceLocation><wsnt:FixedTopicSet>true</wsnt:FixedTopicSet><wstop:TopicSet><tns1:VideoSource><MotionAlarm wstop:topic="true"><tt:MessageDescription IsProperty="true"><tt:Source><tt:SimpleItemDescription Name="Source" Type="tt:ReferenceToken"></tt:SimpleItemDescription></tt:Source><tt:Data><tt:SimpleItemDescription Name="State" Type="xs:boolean"></tt:SimpleItemDescription></tt:Data></tt:MessageDescription></MotionAlarm><GlobalSceneChange><ImagingService wstop:topic="true"><tt:MessageDescription IsProperty="true"><tt:Source><tt:SimpleItemDescription Name="Source" Type="tt:ReferenceToken"></tt:SimpleItemDescription></tt:Source><tt:Data><tt:SimpleItemDescription Name="State" Type="xs:boolean"></tt:SimpleItemDescription></tt:Data></tt:MessageDescription></ImagingService></GlobalSceneChange></tns1:VideoSource><tns1:RuleEngine><TamperDetector><Tamper wstop:topic="true"><tt:MessageDescription IsProperty="true"><tt:Source><tt:SimpleItemDescription Name="VideoSourceConfigurationToken" Type="tt:ReferenceToken"></tt:SimpleItemDescription></tt:Source><tt:Data><tt:SimpleItemDescription Name="IsTamper" Type="xs:string"></tt:SimpleItemDescription></tt:Data></tt:MessageDescription></Tamper></TamperDetector></tns1:RuleEngine><tns1:Media><ProfileChanged wstop:topic="true"><tt:MessageDescription IsProperty="false"><tt:Source><tt:SimpleItemDescription Name="Token" Type="tt:ReferenceToken"></tt:SimpleItemDescription></tt:Source></tt:MessageDescription></ProfileChanged><ConfigurationChanged wstop:topic="true"><tt:MessageDescription IsProperty="false"><tt:Source><tt:SimpleItemDescription Name="Token" Type="tt:ReferenceToken"></tt:SimpleItemDescription><tt:SimpleItemDescription Name="Type" Type="xs:string"></tt:SimpleItemDescription></tt:Source></tt:MessageDescription></ConfigurationChanged></tns1:Media></wstop:TopicSet><wsnt:TopicExpressionDialect>http://docs.oasis-open.org/wsn/t-1/TopicExpression/Concrete</wsnt:TopicExpressionDialect><wsnt:TopicExpressionDialect>http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet</wsnt:TopicExpressionDialect><tev:MessageContentFilterDialect>http://www.onvif.org/ver10/tev/messageContentFilter/ItemFilter</tev:MessageContentFilterDialect><tev:MessageContentSchemaLocation>http://www.onvif.org/onvif/ver10/schema/onvif.xsd</tev:MessageContentSchemaLocation></tev:GetEventPropertiesResponse></s:Body></s:Envelope>
2021-08-10 21:43:50.449 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:CreatePullPointSubscription
2021-08-10 21:43:50.490 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tt="http://www.onvif.org/ver10/schema"><s:Body><trt:GetStreamUriResponse><trt:MediaUri><tt:Uri>rtsp://192.168.0.214:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif</tt:Uri><tt:InvalidAfterConnect>true</tt:InvalidAfterConnect><tt:InvalidAfterReboot>true</tt:InvalidAfterReboot><tt:Timeout>PT0S</tt:Timeout></trt:MediaUri></trt:GetStreamUriResponse></s:Body></s:Envelope>
2021-08-10 21:43:50.491 [DEBUG] [amera.internal.onvif.OnvifConnection] - GetStreamUri:rtsp://192.168.0.214:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
2021-08-10 21:43:50.556 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/EventPortType/CreatePullPointSubscriptionResponse</wsa5:Action></s:Header><s:Body><tev:CreatePullPointSubscriptionResponse><tev:SubscriptionReference><wsa5:Address>http://192.168.0.214/onvif/Subscription?Idx=1</wsa5:Address></tev:SubscriptionReference><wsnt:CurrentTime>2021-08-10T14:43:48Z</wsnt:CurrentTime><wsnt:TerminationTime>2021-08-10T14:53:48Z</wsnt:TerminationTime></tev:CreatePullPointSubscriptionResponse></s:Body></s:Envelope>
2021-08-10 21:43:50.557 [DEBUG] [amera.internal.onvif.OnvifConnection] - subscriptionXAddr=/onvif/Subscription?Idx=1
2021-08-10 21:43:50.558 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:43:50.625 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:43:48Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:53:48Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:VideoSource/MotionAlarm</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2021-08-10T14:43:48Z" PropertyOperation="Initialized"><tt:Source><tt:SimpleItem Name="Source" Value="VideoSource000"></tt:SimpleItem></tt:Source><tt:Data><tt:SimpleItem Name="State" Value="false"></tt:SimpleItem></tt:Data></tt:Message></wsnt:Message></wsnt:NotificationMessage></tev:PullMessagesResponse></s:Body></s:Envelope>
2021-08-10 21:43:50.626 [DEBUG] [amera.internal.onvif.OnvifConnection] - Onvif Event Topic:VideoSource/MotionAlarm, Data:State, Value:false
2021-08-10 21:43:50.630 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:43:50.661 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:44:48Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:43:48Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:43:50.662 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:43:51.652 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:43:49Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:44:48Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:VideoSource/GlobalSceneChange/ImagingService</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2021-08-10T14:43:48Z" PropertyOperation="Initialized"><tt:Source><tt:SimpleItem Name="Source" Value="VideoSource000"></tt:SimpleItem></tt:Source><tt:Data><tt:SimpleItem Name="State" Value="false"></tt:SimpleItem></tt:Data></tt:Message></wsnt:Message></wsnt:NotificationMessage></tev:PullMessagesResponse></s:Body></s:Envelope>
2021-08-10 21:43:51.653 [DEBUG] [amera.internal.onvif.OnvifConnection] - Onvif Event Topic:VideoSource/GlobalSceneChange/ImagingService, Data:State, Value:false
2021-08-10 21:43:51.655 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:43:51.739 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:44:49Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:43:49Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:43:51.741 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:43:52.671 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:43:50Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:44:49Z</tev:TerminationTime><wsnt:NotificationMessage><wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:VideoSource/MotionAlarm</wsnt:Topic><wsnt:Message><tt:Message UtcTime="2021-08-10T14:43:48Z" PropertyOperation="Changed"><tt:Source><tt:SimpleItem Name="Source" Value="VideoSource000"></tt:SimpleItem></tt:Source><tt:Data><tt:SimpleItem Name="State" Value="false"></tt:SimpleItem></tt:Data></tt:Message></wsnt:Message></wsnt:NotificationMessage></tev:PullMessagesResponse></s:Body></s:Envelope>
2021-08-10 21:43:52.672 [DEBUG] [amera.internal.onvif.OnvifConnection] - Onvif Event Topic:VideoSource/MotionAlarm, Data:State, Value:false
2021-08-10 21:43:52.673 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:43:52.748 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:44:50Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:43:50Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:43:52.749 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:43:54.132 [DEBUG] [era.internal.handler.IpCameraHandler] - Binding has no snapshot url. Will use your CPU and FFmpeg to create snapshots from the cameras RTSP.
2021-08-10 21:43:54.137 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Starting ffmpeg with this command now:-rtsp_transport tcp -threads 1 -skip_frame nokey -hide_banner -loglevel warning -i rtsp://onvif:********@192.168.0.214:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif -an -vsync vfr -q:v 2 -update 1 http://127.0.0.1:54321/snapshot.jpg
2021-08-10 21:44:00.820 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:43:58Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:44:50Z</tev:TerminationTime></tev:PullMessagesResponse></s:Body></s:Envelope>
2021-08-10 21:44:00.821 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:44:00.868 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:44:58Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:43:58Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:44:00.870 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:44:08.929 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:44:06Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:44:58Z</tev:TerminationTime></tev:PullMessagesResponse></s:Body></s:Envelope>
2021-08-10 21:44:08.971 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:44:09.025 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:45:06Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:44:06Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:44:09.026 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:44:17.043 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:44:14Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:45:06Z</tev:TerminationTime></tev:PullMessagesResponse></s:Body></s:Envelope>
2021-08-10 21:44:17.044 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:44:17.081 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:45:14Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:44:14Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:44:17.082 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:44:25.118 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:44:22Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:45:14Z</tev:TerminationTime></tev:PullMessagesResponse></s:Body></s:Envelope>
2021-08-10 21:44:25.162 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:44:25.246 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:45:22Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:44:22Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:44:25.247 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:44:33.220 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:44:30Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:45:22Z</tev:TerminationTime></tev:PullMessagesResponse></s:Body></s:Envelope>
2021-08-10 21:44:33.273 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:44:33.338 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:45:30Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:44:30Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:44:33.339 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:44:41.305 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:44:38Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:45:30Z</tev:TerminationTime></tev:PullMessagesResponse></s:Body></s:Envelope>
2021-08-10 21:44:41.306 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:44:41.356 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:45:38Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:44:38Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:44:41.356 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:44:49.428 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:44:46Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:45:38Z</tev:TerminationTime></tev:PullMessagesResponse></s:Body></s:Envelope>
2021-08-10 21:44:49.429 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:Renew
2021-08-10 21:44:49.467 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wsa5="http://www.w3.org/2005/08/addressing"><s:Header><wsa5:Action>http://docs.oasis-open.org/wsn/bw-2/SubscriptionManager/RenewResponse</wsa5:Action></s:Header><s:Body><wsnt:RenewResponse><wsnt:TerminationTime>2021-08-10T14:45:46Z</wsnt:TerminationTime><wsnt:CurrentTime>2021-08-10T14:44:46Z</wsnt:CurrentTime></wsnt:RenewResponse></s:Body></s:Envelope>
2021-08-10 21:44:49.468 [TRACE] [amera.internal.onvif.OnvifConnection] - Sending ONVIF request:PullMessages
2021-08-10 21:44:57.521 [TRACE] [amera.internal.onvif.OnvifConnection] - Onvif reply is:<?xml version="1.0" encoding="utf-8" standalone="yes" ?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:sc="http://www.w3.org/2003/05/soap-encoding" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:tns1="http://www.onvif.org/ver10/topics"><s:Header><wsa5:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesResponse</wsa5:Action></s:Header><s:Body><tev:PullMessagesResponse><tev:CurrentTime>2021-08-10T14:44:55Z</tev:CurrentTime><tev:TerminationTime>2021-08-10T14:45:46Z</tev:TerminationTime></tev:PullMessagesResponse></s:Body></s:Envelope>
When connection is stopped I canāt see Onvif Renew and PullMessages requests, openHAB is cannot receive the motionAlarm also.
Is there anyone get the same issue?
matt1
(Skinah)
August 13, 2021, 11:01am
2441
No one has reported that before as the binding checks the ONVIF is still alive every 8 seconds and will automatically re-connect, however it relies on a connection failure to occur. From your logs the camera just stopped replying, so this may need improving in the binding if multiple cameras do this. Does this happen all the time or is it an isolated time? Normally the snapshot is getting fetched and if the camera stops responding it would normally detect the snapshot has failed and launch into re-connecting, since your camera reports no snapshot url (which violates ONVIF standards) this never happens. At some point it may be an idea to upgrade the camera.
roli
(Andrej Rolih)
August 22, 2021, 1:45am
2442
Hi!
Recently I replaced 2 cameras on my Dahua NVR (8 port XVR5108HS-I2) and something weird has started happening with generation of ipcamera.mjpeg (via ffmpeg) for those two cameras (the rest of them work fine and I didnāt change any settings for the binging - just the cameras were replaced). Basically the āstreamā freezes very quickly. On an android tablet in Habpanel I pretty much see the stream for a second or two and it disappears. If I just open the ipcamera.mjpeg in a browser on my computer I will see the stream for a few minutes but it will very quickly freeze as well (strangely enough for one camera it always seems to happen when a car passes by on a road).
The browser console gives me nothing, and the binding trace log is not really any more useful either:
2021-08-22 03:24:53.154 [DEBUG] [pcamera.internal.StreamServerHandler] - Stream Server recieved request GET:/ipcamera.mjpeg
2021-08-22 03:24:53.156 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - Starting ffmpeg with this command now:******** ...
2021-08-22 03:24:55.756 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - [swscaler @ 0x555e4a0a7680] deprecated pixel format used, make sure you did set range correctly
2021-08-22 03:25:05.302 [DEBUG] [hab.binding.ipcamera.internal.Ffmpeg] - More than 1000 frames duplicated
2021-08-22 03:27:37.054 [DEBUG] [pcamera.internal.StreamServerHandler] - Stream server is going to close an idle channel.
2021-08-22 03:27:37.055 [DEBUG] [era.internal.handler.IpCameraHandler] - All ipcamera.mjpeg streams have stopped.
The parameters that I have set for the ffmpeg output are these:
-b:v 2000 -r 8 -vf scale=640:-2 -update 1
Iāve been struggling with this for a week and I am completely lost. Any ideas on what could be wrong? I find it completely weird since only the cameras changed and nothing else.
matt1
(Skinah)
August 23, 2021, 6:43am
2443
You should open your own thread and provide more details.
What cameras do you have? Are they the same brand and model as the ones you replaced?
What is the openhab server, is it a pi2 for example?
roli
(Andrej Rolih)
August 23, 2021, 8:02pm
2444
Done. If you (or anyone else) has any ideasā¦
Hi!
Recently I replaced 2 cameras on my Dahua NVR (8 port XVR5108HS-I2) and something weird has started happening with generation of ipcamera.mjpeg (via ffmpeg) for those two cameras (the rest of them work fine and I didnāt change any settings for the binging - just the cameras were replaced). Basically the āstreamā freezes very quickly. On an android tablet (two different ones) in Habpanel I pretty much see the stream for a second or two and it disappears. If I just open the ipcamera.mjpeg in ā¦
boogie
(Christoph)
August 24, 2021, 11:22am
2445
Hi @matt1 , sorry for my late response, i was on vacation and have now found the time to take a look. In any case, thank you very much for your fix, looks good now!
Regarding my problem, the settings on the camera and in the binding were all correct, but a bug may have crept in during one of the last firmware updates from Instar. After spending many hours on it, i decided to do a factory reset, after that was done, everything worked fine.
In any case, thank you very much for your support!
tizen
(Amin)
September 5, 2021, 6:02pm
2446
How is the performance of this binding on rasberry pi 3?
I did the setup but there is huge delay. Are there any settings i can tweak? I m new to ip camera with openhab + rasberry pi
Regards,
Amin
matt1
(Skinah)
September 5, 2021, 10:37pm
2447
What feature are you getting a delay with? Have you read the bindings documentation? Do a search on delay and there are plenty of tips in there on how to tweak.
Python
(Chris)
September 8, 2021, 12:23am
2448
So natively though the Hikvision NVR or Camera web interface i canāt add multiple Linecrossing lines but i just found out though testing that i can add multiple lines using the ISAPI configuration:
If i push configuration to: http://x.x.x.x/ISAPI/Smart/LineDetection/1/lineitem/ 1
and icrement the last number up thats in bold: eg.:
http://x.x.x.x/ISAPI/Smart/LineDetection/1/lineitem/1
http://x.x.x.x/ISAPI/Smart/LineDetection/1/lineitem/2
http://x.x.x.x/ISAPI/Smart/LineDetection/1/lineitem/3
I can have multiple Linecrossing lines that get triggered.
I was viewing the alert stream and each alert depending on the line crossed triggers a unique event based on tag:
<regionID>2</regionID>
The number between the regionID tag reflects the ISAPI lineitem: http://x.x.x.x/ISAPI/Smart/LineDetection/1/lineitem/ 2
Is it possible to have additional channels added to the binding to be able to trigger rules depending on which line is crossed:
Here is the output from my alertStream:
For http://x.x.x.x/ISAPI/Smart/LineDetection/1/lineitem/ 1
--boundary
Content-Type: application/xml; charset="UTF-8"
Content-Length: 1263
<EventNotificationAlert version="2.0" xmlns="http://www.hikvision.com/ver20/XMLSchema">
<ipAddress>192.168.2.201</ipAddress>
<portNo>80</portNo>
<protocol>HTTP</protocol>
<macAddress>c0:51:7e:c2:c5:33</macAddress>
<channelID>1</channelID>
<dateTime>2021-09-07T20:08:07-5:00</dateTime>
<activePostCount>7</activePostCount>
<eventType>linedetection</eventType>
<eventState>active</eventState>
<eventDescription>linedetection alarm</eventDescription>
<DetectionRegionList>
<DetectionRegionEntry>
<regionID>1</regionID>
<sensitivityLevel>60</sensitivityLevel>
<RegionCoordinatesList>
<RegionCoordinates>
<positionX>360</positionX>
<positionY>163</positionY>
</RegionCoordinates>
<RegionCoordinates>
<positionX>863</positionX>
<positionY>185</positionY>
</RegionCoordinatesList>
</DetectionRegionEntry>
</DetectionRegionList>
<channelName>Front Yard</channelName>
<Extensions version="1.0" xmlns="urn:psialliance-org">
<serialNumber xmlns="urn:selfextension:psiaext-ver10-xsd">DS-2CD2347G1-LU20201103AAWRE96761883</serialNumber>
<eventPush xmlns="urn:selfextension:psiaext-ver10-xsd">IO&&DS-2CD2347G1-LU20201103AAWRE96761883,2021-09-07T20:08:07-5:00,1.0</eventPush>
</Extensions>
</EventNotificationAlert>
For http://x.x.x.x/ISAPI/Smart/LineDetection/1/lineitem/ 2
--boundary
Content-Length: 1261
<ipAddress>192.168.x.xx</ipAddress>
<portNo>80</portNo>
<dateTime>2021-09-07T20:06:58-5:00</dateTime>
<activePostCount>1</activePostCount>
<sensitivityLevel>50</sensitivityLevel>
<RegionCoordinates>
<positionX>530</positionX>
<positionY>1</positionY>
<RegionCoordinates>
<positionY>900</positionY>
<eventPush xmlns="urn:selfextension:psiaext-ver10-xsd">IO&&DS-2CD2347G1-LU20201103AAWRE96761883,2021-09-07T20:06:58-5:00,1.0</eventPush>
</Extensions>
As you can see the value within the regionID tag match up
matt1
(Skinah)
September 8, 2021, 12:28am
2449
Python:
Is this the line that determins the line crossed? EDIT: sorry re-read your post and you already answered it.
Thanks for posting this as it would be great if my camera has this ability. Will have a look into it soon.
Python
(Chris)
September 8, 2021, 12:33am
2450
Yes! I re-read my post a few times and made some edits to clarify. Give it a tryā¦ i was trying to figure out the ISAPI URL for controlling the MIN/MAX object sizes that trigger smart events and came across this.
Hereās what i did to alter these values:
/usr/bin/curl -k --silent -H 'Content-Type:application/xml' -X PUT -d "
<LineItem>
<id>2</id>
<enabled>false</enabled>
<directionSensitivity>any</directionSensitivity>
<CoordinatesList>
<Coordinates>
<positionY>999</positionY>
</Coordinates>
<Coordinates>
<positionY>100</positionY>
</Coordinates>
</CoordinatesList>
</LineItem>" http://$IP/ISAPI/Smart/LineDetection/1/lineitem/2 --digest -u $username:$password
Update $IP, $USERNAME and $PASSWORD to reflect your camera and login information.
You can see the lines added if you enable RULES on your NVR. Here was my test (the verticle line down my driveway) which works. Im pretty excited to have multiple lines now
Python
(Chris)
September 10, 2021, 2:57am
2451
Did this work for your cameraās ?
matt1
(Skinah)
September 16, 2021, 12:12am
2452
Not sure when I will get some time as I want to update the firmware first and then do some testing and setup on the latest firmware. I want to have multiple lines, so should not be too long and I expect it will work as the firmware is now made generic and not compiled for each camera anymore.
narf27
(Peter)
September 17, 2021, 8:50am
2453
Hey guys!
iām using this binding with my door bell with these cam.things:
Thing ipcamera:generic:Entry
ipAddress="192.168.178.151", password="yes", username="admin", pollTime=1000, serverPort=54323,
snapshotUrl="http://192.168.178.151:8080/?action=snapshot",
mjpegUrl="http://192.168.178.151:8080/?action=stream"
and there cam.items:
String HttpOnlyMjpegStreamUrl "Mjpeg Stream" (Group_HabPanel_Dashboard) { channel="ipcamera:generic:Entry:mjpegUrl" }
String HttpOnlyImageUrl "Image Url" { channel="ipcamera:generic:Entry:imageUrl" }
with Habpanel i was able to display the video with a image widget and the HttpOnlyMjpegStreamUrl item.
i have tried the same with the new MainUI and it still works with a Image Card. is that the right way to display the stream or will this cause too much load for my rpi?
matt1
(Skinah)
September 17, 2021, 1:12pm
2454
Image card works well, but these have more features especially if the camera has PTZ.
OH3 Widget: Building a camera widget - Add-ons / UIs - openHAB Community
