The binding should work with both however if it has been using DIGEST the binding may refuse to switch to BASIC and this is a security feature as a common hacking technique is to use whats called a ''Downgrade attack". Possible you need to do a restart after having switched the camera to BASIC from DIGEST.
If you want this looked at in case it is a compatiblity issue, please start your own thread or PM me with some TRACE log output, I just need to see what the HTTP headers are for your camera and some lines to see how the binding is handling the headers.
I introduced some breaking changes, see here as one would have caused you problems. Also clean out tmp and cache.
2019-03-23 22:55:16.984 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'IP_camera.things'
2019-03-23 22:55:17.101 [me.event.ThingUpdatedEvent] - Thing 'ipcamera:HIKVISION:002' has been updated.
2019-03-23 22:55:24.513 [INFO ] [ing.ipcamera.handler.IpCameraHandler] - The 'ONVIF media profile 1' is using mjpeg and will allow you to use the new streaming features if reachable with HTTP.
2019-03-23 22:55:31.581 [INFO ] [ing.ipcamera.handler.IpCameraHandler] - IP Camera at 192.168.1.45:80 is now online.
2019-03-23 22:55:31.593 [INFO ] [ing.ipcamera.handler.IpCameraHandler] - IpCamera stream server has started on port:1021.
2019-03-23 22:55:33.581 [WARN ] [ing.ipcamera.handler.IpCameraHandler] - The alarm checking stream was not running. Cleaning channels and then going to re-start it now.
In the sitemap:
Text label="XXX" icon="camera" {Video url="http://192.168.1.45:1021/ipcamera.mjpeg" encoding="mjpeg"}
Also when Iām trying to reach it from browser, nothing happens.
Everything looks right. When you try and open the stream watch the log in debug mode (see readme file for how to do this) also when the server starts look at the log. Does your openhab machine have more than 1 network card? It may be serving on the wrong network card if u have multiples.
Thank you for the answer. Now I see the problem. On the sitemap, the IP address belongs to the camera not to the server (which is an RPi). Now it works partially. I can see the the stream through browser, in Classic UI, but not in the OpenHAB app (iPhone/iOS). Any idea about this?
I tried the webview option: I have an image (not optimized for the mobile), and the app freezes, I need to close it manually.
Yes that is what I found, the iOS app has issues. Image for snapshots does not work, video items do not work and webview shows a picture and then crashes. Android app works great.
Conclusion is the iOS app needs some work. Use habpanel or basic/classic ui in a browser and it works.
Not sure I follow your statement about using ip of camera in the sitemap, you use the link the binding gives in the streaming URL channel. If you think the readme needs changing to make something clearer just let me know.
Sad to hear it
I havenāt planned to change my mobile May be I need to be patient and sometime itāll work⦠(or not )
I have another issue with it, as some of the icons sometimes are not shown but there is no regurality⦠Iāve been waiting to be solved this for about a year, but nothing happened
The readme is OK, doesnāt need to be changed. I was too tired and careless yesterday.
Thanks for your quick answers, and you did a brilliant work with this binding. I will keep checking the updates
Hi @matt1 ,
I am testing an Amcrest dvr And Iād love to get this all working, so far Iām able to get 1 camera connected and so far all the channels I have tested work, except⦠When I add a second camera from the same dvr all of the channels seem to return data from only the first camera connected to the dvr (Image,motion alarm,etc).
I have tried adding it as both an Amcrest and as a DAHUA within the paper ui (I read in the readme I should try that) with the same results.
the dvr in question is Amcrest AMDVTENL8-H5 Iām not really sure what I should try next
I have never had someone with a NVR contact me, so the binding will not do anything different until I have some urls confirmedā¦
Snapshot does this give you the snapshot from the second channel? http://ipaddress/cgi-bin/snapshot.cgi?channel=2
You can use the snapshot url override feature to manually enter this in for each camera.
I will also need an example of the alarm stream and what comes up in a browser for this URL?
Gāday @matt1, Iām currently using āipcamera2019-03-19.zipā and it wouldnāt work without adding user/pswd info to the āSNAPSHOT_URL_OVERIDEā parameter. Wondering if this is now the default behaviour? And why doesnāt it use the values in the āUSERNAMEā and " PASSWORD" parameters?
this is the old (commented) version and new (working) version:
That will be the onvif finding the URL for you as you do not need to supply the URL if onvif works on your camera. My guess is a reboot and onvif made it work.
Hello @matt1 I just wanted to say thank you for this binding. I played a few days with it and my foscam camera and it works well. You work is very much appreciated
That sitemap you posted shows you are not using the binding but are trying to get the camera to send directly. For cameras like foscam that place the user and pass into the URL query string it works, but for other cameras it will not work. The issue is most if not all browsers are discontinuing the embedded user and pass that you are trying to do. This is because of security concerns and the standards specify it should not be done hence why browsers are removing support for something that used to work.
See the readme file for this binding as it guides you through what to do. You will need to remove the xxx:xxx@ from your URL with the binding.
[io.netty.channel.nio.NioEventLoop ] - Selector.select() returned prematurely 512 times in a row; rebuilding Selector io.netty.channel.nio.SelectedSelectionKeySetSelector@52f424a3
It will be as this is the line that is hardcoded into the binding for Dahua. It would not work if it was not using a substream that is setup for mjpeg.
Ok that probably explains the high CPU usage, there is an open issue for a similar report at the Netty github and they are not able to reproduce it, but the error is the same as yours and reports of high CPU. I can not reproduce it as it has been working fine here for weeks but I have not tested with multiple cameras at the same time. You will need to strip it back to a single camera and try changing different things until you find the cause. There is a newer version of Netty that I can upgrade to next time I am building a jar to see if it fixes. Also try cleaning the cache and tmp folders and turning your server off and back on again.
Hi Matt
sorry another question. Does the frame rate in the āthingā need to match the actual camera? I have the cameras defined at 25FPS, but Iām happy to have them set to 10 in the thing configuration.
