Can anyone advise how to make those changes to JDBC persistance DB if possible.
remove the suffix on the Item table names so they match exactly what’s on items table?
change the time to be in epoch?
is it possible to put all the sensors in one table instead of different tables and have another column indicating the sensor name?
lastly is there a way to track openhhab reboot time every time it reboot and log it to the db?
and is it possible to install JDBC from the command line without the UI?
my config file:
# E R R O R H A N D L I N G
# optional when Service is deactivated (optional, default: 0 -> ignore)
#errReconnectThreshold=
# I T E M O P E R A T I O N S
# optional tweaking SQL datatypes
# see: https://mybatis.github.io/mybatis-3/apidocs/reference/org/apache/ibatis/type/JdbcType.html
# see: http://www.h2database.com/html/datatypes.html
# see: http://www.postgresql.org/docs/9.3/static/datatype.html
# defaults:
#sqltype.CALL = VARCHAR(200)
#sqltype.COLOR = VARCHAR(70)
#sqltype.CONTACT = VARCHAR(6)
#sqltype.DATETIME = DATETIME
#sqltype.DIMMER = TINYINT
#sqltype.LOCATION = VARCHAR(30)
#sqltype.NUMBER = DOUBLE
#sqltype.ROLLERSHUTTER = TINYINT
#sqltype.STRING = VARCHAR(65500)
#sqltype.SWITCH = VARCHAR(6)
# For Itemtype "Number" default decimal digit count (optional, default: 3)
#numberDecimalcount=
# T A B L E O P E R A T I O N S
# Tablename Prefix String (optional, default: "item")
# for Migration from MYSQL-Bundle set to 'Item'.
tableNamePrefix=item
# Tablename Prefix generation, using Item real names or "item" (optional, default: false -> "item")
# If true, 'tableNamePrefix' is ignored.
tableUseRealItemNames=true
# Tablename Suffix length (optional, default: 4 -> 0001-9999)
# for Migration from MYSQL-Bundle set to 0.
tableIdDigitCount=false
# Rename existing Tables using tableUseRealItemNames and tableIdDigitCount (optional, default: false)
# USE WITH CARE! Deactivate after Renaming is done!
rebuildTableNames=true
# D A T A B A S E C O N N E C T I O N S
# Some embeded Databases can handle only one Connection (optional, default: configured per database in packet org.openhab.persistence.jdbc.db.* )
# see: https://github.com/brettwooldridge/HikariCP/issues/256
# jdbc.maximumPoolSize = 1
# jdbc.minimumIdle = 1
# T I M E K E E P I N G
# (optional, default: false)
enableLogTime=true
