Thank for your answer!
Hm, this would be good to have logarithmic axis as a feature in OH charts.
Actually I don’t understand why OH is limiting the features of echarts. Is there any reason for this? Or is there a way to sneak around this limitation by using echarts directly?
I don’t know for sure and can only speculate. My guess is that the built-in charting in MainUI is really only ever supposed to be simple. There are so many other solutions out there, e.g. Grafana, that can be used if advanced charting is required that it’s simply not worth the effort to try and integrate a more advanced solution directly into the UI.
I’m sure there is, but I have never tried so I can’t really help there.
prevents the standard root-level options (grid, xAxis, yAxis etc.) to be overridden by what’s in the options config object. It would not be the case if that ...chartConfig had been at the end, so it’s an easy fix.
@ysc thanks for this interesting insights. Unfortunately I was not able to define the yAxis logarithmic.
Could you please extend the first code block example in your previous post?
I tried to move the yAxis definition below options: , see below, but this could not be parsed by OH.
period: D
label: FRITZBox Traffic
sidebar: true
order: "3000"
options:
yAxis:
- component: oh-value-axis
gridIndex: 0
type: log
logBase: 1024
name: Bit / s
nameLocation: center
nameGap: 40
slots:
grid:
- component: oh-chart-grid
includeLabels: true
xAxis:
- component: oh-time-axis
gridIndex: 0
series:
- component: oh-time-series
gridIndex: 0
xAxisIndex: 0
yAxisIndex: 0
type: line
item: WANDevice_FRITZBox_7490_TotalReceived_Bit_per_second
color: green
markLine:
data:
- type: average
markPoint:
label:
backgroundColor: auto
data:
- type: max
May be the syntax I used was wrong or do you mean the fix would be possible but your suggestion does not work in OH 3.2?
