@JustinG , thanks so much for pointing us in this direction.
Would it be possible to replace the core f7-row component by a slider, instead of the somewhat difficult to edit HMS-text boxes. I have tried that. My struggles are:
how to set the initial value (as read from the metadata). when using oh-slider-item that’s not possible, via the value parameter. when using f7-range, that can be done via value, but not being a css expert, it’s difficult for me to determine the wrap-components around f7-range, which ressemble the oh-slider-item.
how would a value change on the slider trigger an action command (as is done through oh-link), to change the helper item and run the rule.
