Is it possible to stop a binding?
Hi, i have again a very special question and hope for an answer:
Im using the km200 V2 binding for controlling my Buderus System. But only in Winter now during the
summer season the Oven is switched off so i got tons of logs saying the communication is not
possibile. SO is it possible to stop a binding in karaf from working without changing my whole configuration like: Its summer switch binding OFF and if winter switch binding ON???
You can use PaperUI to set a Thing OFFLINE
You can disable the thing in PaperUI very easy. Thats probably better than stopping the binding:
Press one of the buttons I have marked, and you´ll disable the thing.
Wow, thanks a lot perfect answer thats the sulution for my problem
You can also do this automatically, or based on calendar using NGRE / Jython scripting.
