Is it possible to use dynamic widget item for display using json data?
I am wondering if I can display data on OH3 overview page a weather forecast. I have done by using lots of items but I thought the data that is displayed is the same format so can I make it dynamic and cut down the number of items used?
Use something like: =(items.BOM_Day1_ForecastDateAndTime.displayState) but make it dynamic
What I want to do is get the weather data in json format and there is a site in Australia that can do that. I put all the data into one item called BomMV_Data using the http binding.
That works and I can see the data.
I can also parse the data in JavaScript so I know I can do that as well.
var obj = itemRegistry.getItem("BomMV_Data").getState();
var test = JSON.parse(obj) ;
for (var count = 0; count < 7; count++) {
logger.info('Icon: ' + test.data[count].icon_descriptor);
logger.info('Short text: ' + test.data[count].short_text);
logger.info('Date: ' + test.data[count].date);
logger.info('Max: ' + test.data[count].temp_max);
logger.info('Min: ' + test.data[count].temp_min);
logger.info('Forecast ' + test.data[count].extended_text);
2021-03-15 09:47:30.709 [INFO ] [org.openhab.rule.scratchpad ] - Icon: sunny
2021-03-15 09:47:30.710 [INFO ] [org.openhab.rule.scratchpad ] - Short text: Sunny.
2021-03-15 09:47:30.711 [INFO ] [org.openhab.rule.scratchpad ] - Date: 2021-03-14T13:00:00Z
2021-03-15 09:47:30.712 [INFO ] [org.openhab.rule.scratchpad ] - Max: 20
2021-03-15 09:47:30.713 [INFO ] [org.openhab.rule.scratchpad ] - Min: 7
2021-03-15 09:47:30.714 [INFO ] [org.openhab.rule.scratchpad ] - Forecast Sunny. Light winds.
What I don’t know and can’t find any information is whether I can use the same sort of logic to display on the overview page.
I have tried lots of different things using the developer side bar widget tester but can’t crack the code I need.
This didn’t work either:
=transform(ā€œJSONPATHā€,"$.data[0].extended_text",(items.BomMV_Data.state))
My question is can it be done?
Maybe a router component
So it doesn’t look easy as I was hoping. Looks like it is back to having lots of items. :frowning_face:
It’s certainly possible with a oh-repeater, I have an item holding some JSON in its state like:
[{"conso": "5", "time": "02/03/2021"}, {"conso": "17", "time": "03/03/2021"}, ...]
I’m displaying it in a list like this:
    component: oh-list
        style:
          min-width: 250px
          --f7-list-item-after-font-size: 16px
          --f7-list-item-after-font-weight: bold
          --f7-list-item-after-text-color: var(--f7-text-color)
      slots:
        default:
          - component: oh-repeater
              for: day
              in: =JSON.parse(items.Gazpar_DailyRaw.state)
              fragment: true
            slots:
              default:
                - component: oh-list-item
                    title: =dayjs(loop.day.time.substring(6) + '-' + loop.day.time.substring(3,5) +
                      '-' + loop.day.time.substring(0,2) +
                      'T02:00:00.000Z').format('dddd D MMMM')
                    after: =loop.day.conso + ' kWh (' + Math.round(
                      loop.day.conso * (0.00843 + 0.03610) * 120) / 100 + ' €)'
Thanks for that. What I was hoping for was a single liner where I could just pull out data for one item if needed.
Similar to this: =(items.BOM_Day1_ForecastDateAndTime.displayState) but obviously make it variable. Like this: =transform(ā€œJSONPATHā€,"$.data[0].extended_text",(items.BomMV_Data.state)) but I can’t seem to be able to simply do that without creating lots of items.
I guess it can’t be done simply.
The statement works and displays the ALL of the data:
=JSON.parse(items.BomMV_Data.state)
If I can just find the syntax to get data[0].extended_text out of that…
So close.
YES!!! Got it finally:
=JSON.parse(items.BomMV_Data.state).data[0].extended_text
Output from the above command:
Sunny. Light winds.
Now I don’t need lots of items I just need the one with all the data in it.
Now for the next problem how to format the date:
=JSON.parse(items.BomMV_Data.state).data[0].date
Gives: 2021-03-14T13:00:00Z
I would like it to be in local time and formatted like Monday 15
Oh well back to the drawing board.
OK for those who want to know the date format syntax is:
=dayjs(JSON.parse(items.BomMV_Data.state).data[0].date).format(ā€˜dddd MMM D’)
Which gives the output of:
Monday Mar 15
This is what the overview page looks like.
This is what it looks like:
Still a work in progress but it does work.
Thanks @ysc the example you gave me had enough clues in it to get it to do what I wanted.
Hi.
I have looked at your example but I can’t get it to do what I want which is loop through the json data in the one item I have and change the index number to the next set of data. The json file is weather data and the json format is data[0].whatever What I would like to be able to do is grab any of the data and list it.
Like this:
data[0].short_text
data[1].short_text
data[2].short_text
In other words be able to substitute an index number in between the [] like [indx]
I am new to this stuff and just need an example.
I tried this but it didn’t work:
  style:
    min-width: 250px
slots:
  default:
        for: day
        in: =JSON.parse(items.BomMV_Data.state)
        fragment: true
      slots:
        default:
              title: =dayjs(loop.day.data[0].date)
              after: =loop.day.data[0].short_text
I am not even sure I am doing this in the right place. I am trying to do it on the overview page:
The black square with nothing beside it is what I am testing, but nothing works.
The data I am pulling down is here: https://api.weather.bom.gov.au/v1/locations/r659gg/forecasts/daily
I thought I was getting to know this works when I finally got the data to display earlier but I really would like to do dynamic variable stuff.
Should I be doing this on the overview page or is this a widget type of exercise?
Any help or clues greatly appreciated.
