I would like to move some logic from my rule files to standard java code, which can be unit tested.
Is it possible to put a simple pojo jar file into openhab2 and use that code in rules - as you would use for example the DateTime object.
So far, I have no idea to achieve this. “bundle:install” didn’t work either.
My vision:
import mycode.OpenHabAirControl
rule testJar
Time cron ...
var OpenHabAirControl obj = new OpenHabAirControl()
obj.setArg1("1")
obj.setArg2("2")
var String newState = obj.compute
itemAirControl.sendCommand(newState)
I don’t know the direct answer to your question but suspect it is potentially possible. I would look to see how to build an add-on, which is essentially what you would be writing, for how to deploy it. In particular, look to see how to write an Action.
Alternatively, I would recommend looking at the JSR233 binding which is going to be included in the snapshot version of OH 2 any day now. This would allow you to write rules in Jython, JavaScript, or Groovy, all three of which allow unit testing of rules. This would be my first recommendation.
Another alternative would be to use the Exec binding and/or executeCommandLine, to call your external code. For example, your rule above would become:
val newState = executeCommandLine("java OpenHabAirControl 1 2", 5000)
Assumptions:
correct paths to java and OpenHabAirControl.class need to be right
the script returns a String that can be easily parsed into a state itemAirControl supports
