Hello.
I have this Mi Desk Lamp : https://www.mi.com/global/smartlamp/
Is it compatible with OpenHab ?
With which binding, Xiaomi Mi IO binding, or Yeelight binding ? (it’s quite confusing to have both available as bindings, by the way).
In fact, the lamp is autodetected through PaperUI as a thing, then i fulfil everything, but the “device type” stays empty … (as far as i’ve understood, it should be auto-detected). The device shows itself as connected (i suppose, through the IP being reachable), but no configured channels are working.
I tried to manual add the lamp with several device type from Mi IO binding, but without any luck after a couple of hours of trys …
Any idea ?
- is it compatible ?
- with which binding ?
- with which device type ?
(as far as i can tell, i have all the proper infromations - device ID in HEX, token ID, IP, …), and the lamp is working fine in Yeelight App or in Xiaomi Gateway app).
Also :
- i’m running OpenHAB 2.4
- i haven’t found anything about this lamp, neither in the bindings documentation nor in the forum.
Thanks in advance.
