I want it
There is no MQTT action.
But what would you want to do with an action that you cannot do with a String Item bound to a an MQTT topic and publishing a message using postUpdate?
For example:
Item:
String N_D_Update { mqtt=">[mosquitto:entry_sensors/getUpdate:state:*:default]" }
Rule Code:
N_D_Update.postUpdate("update")
The above rule code will publish the word āupdateā to the topic entry_sensors/getUpdate. I use it to request the current status of some sensors.
There is, but you need to be running 1.8.
See: https://github.com/openhab/openhab/wiki/Actions#mqtt-action
Presumably this would also require an MQTT actions jar file installed, correct?
Should be found here (in addons.zip)
Pretty sure this link is deprecated. MQTT action is part of mqtt2 Binding.
Is there a way to install 1.8 from apt-get? I also would like this feature but would really like to keep everything under the package manager.
Not that Iām aware of. Iām running a couple of 1.8-SNAPSHOT addons that I installed manually to my 1.7.1 instance - after removing the version installed by Apt. This works fine, I just wonāt get any updates for those addons via Apt.
Interesting that 1.8 wouldnāt be under the testing/unstable branch.
The distribution packaging mechanism does not currently support āunstableā. It would be nice to have!
There is no mqtt action bundle in this package.
I will submit a pull request to include it in the distribution. Whoops!
Thanks!
Strange, build-list said Build-Duration for MQTT-action was 1.2secs⦠direct Link: https://openhab.ci.cloudbees.com/job/openHAB/lastStableBuild/org.openhab.action$org.openhab.action.mqtt/artifact/org.openhab.action/org.openhab.action.mqtt/1.8.0-SNAPSHOT/org.openhab.action.mqtt-1.8.0-SNAPSHOT.jar
Yes, the jar was being built but not included in the final deliverable. Thaās what @watou fixed.
Expect the new functionality on tonights Jenkins build.
How to post a retained message to topic?
Since the action uses the same underlying MqttService
as the binding, you would set retain
to true
in openhab.cfg
as documented here. I just updated the Actions wiki page with this info as well.
I try to create 2 connections to mqtt retained and not, but it not works for me.
Please view my settings, is it right?
openhab.cfg:
mqtt:wb.url=tcp://192.168.1.4:1883
mqtt:wb.clientId=openhab
mqtt-eventbus:broker=wb
mqtt:wb.retain=false
mqtt:wbr.url=tcp://192.168.1.4:1883
mqtt:wbr.clientId=openhab2
mqtt-eventbus:broker=wbr
mqtt:wbr.retain=true
I see you are defining the mqtt-eventbus:broker
config value twice, once as wb
and again as wbr
should be only one for same server?
And if i use another mqtt server 192.168.1.5 - should i define eventbus:broker for it?
