It’s merged now. You can install it from PaperUI or addons.cfg or however you install bindings. It is no longer required to download the jar file separately. And in fact the latest version of the binding going forward will no longer be available there.
The binding does require code that does not exist in OH 2.4 so you cannot run it on OH 2.4.
After 2.5 is released, I’ll be upgrading as soon as the RPi 4 can handle external booting. But for now, I’ll stick with my current 3.
Thanks for the reply.
@rlkoshak I have just one follow-up question after reading NUT 1.13 binding page:
Is there a mechanism through the binding to tell my RPi3 to power down, if the power has not returned before that UPS’s battery has run out, or should I use updates from the tools to make that decision?
Thanks.
You should install the NUT client on the RPI and configure that to do this for you. Don’t replace a great tool with OH just because you can. Shutting down machines automatically when the battery starts to run low is NUT’s main job. Let it do it’s job.
