I have a HIK Vision NVR with 2 cameras (not ip) on it. How could I bind it with openhab? Thank you!
No idea sorry, try asking at the ipcamtalk forum as the nvr may have the api in it or another model nvr may do it, They will know but at some point if the cameras are old you should consider upgrading them to IP ones. If it is coax cable the good news is that stuff is strong and can pull through cat5 with ease.
